High-quality picture
Powered by 3LCD technology, the EB-425W achieves accurate colour reproduction, important in education for natural-looking flags, maps and diagrams. A White and Colour Light Output of up to 2,500 lumens assures a clear picture, even in daylight, while a contrast ratio of 3,000:1 delivers sharp detail.
Interactive lessons
Attach the optional Epson ELP-IU03 interactive module to captivate the class with interactive presentations. The module works with the projector to make any surface interactive - no screen required. Notes or additions can be created and saved with the included digital pen. For a complete solution, the projector also has an optional tailor-made wall mount.
Convenient to control
The EB-425W is compatible with the Epson ELPCB01 Control and Connection Box, which puts Epson projector controls within easy reach at the front of the classroom. It also keeps cables tidy.
Engaging presentations
Presentations can be made more engaging by plugging in the Epson ELP-DC06 USB document camera to show 3D objects close-up, or by using the HDMI input to display high-definition content. The built-in 16W speaker and microphone input ensure students won't ever struggle to hear.
Easy to use
Super-easy to set up and use, the EB-425W features 3-in-1 USB display, so one cable is all that's needed for visuals, audio and mouse control. The picture can be aligned in seconds using the vertical and horizontal keystone correction, which is unique to Epson in the short-throw category. Plus, the projector can be conveniently turned on and off from a wall switch using the direct power on/off function.
Economical
Schools can make savings thanks to the EB-425W's low total cost of ownership. Its Epson E-TORL lamp produces more light using less energy, and lasts 6,000 hours in eco mode. The filter also has a long life of 5,000 hours for years of trouble-free operation. Further reducing costs and maintenance time, the projectors can be connected to a network to enable remote control and monitoring & broadcast images.
Short-throw WXGA projector
This affordable, 2,500-lumen, short-throw projector can be mounted closer to the screen for fewer shadows when presenting.
- Epson EB-425W - 3LCD projector - LAN
- 3LCD projector - 720p
- Built-in Devices
- Speaker
- Brightness
- 2500 lumens
- Brightness (Colour)
- 2500 lumens
- Contrast Ratio
- 3000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- E-TORL UHE 200 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video LAN
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 1080p
- Video Output
- RGB
- Speakers
- Speaker(s) - internal
- 283 Watt
- 34.5 cm x 27.7 cm x 10.5 cm
- 3.8 kg
- 3-year warranty
- Built-in Devices
- Speaker
Projector
- Brightness
- 2500 lumens
- Contrast Ratio
- 3000:1
- Image Size
- 102 cm - 295 cm
- Throw Ratio
- 0.48 - 0.65:1
- Digital Zoom Factor
- 1.35x
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Bulb type
- Bulb life cycle
- OSD Languages
- Hebrew, Hungarian, Czech, Croatian, Slovenian, Slovak, Ukrainian, English, German, French, Italian, Polish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian
- EPSON 3LCD technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.8
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -15 / +15
- Horizontal Keystone Correction
- -15 / +15
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- 1080p
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Video Output
- Analogue Video Signal
- RGB
Speakers
- Internal
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
Input Device
- External
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x microphone - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A
- Included Accessories
- Wireless remote control
- Security Features
- Security lock slot (cable lock sold separately), password protection
- 283 Watt
- Power Consumption Operational (Standby)
- 0.39 Watt
- 34.5 cm
- 27.7 cm
- 10.5 cm
- 3.8 kg
- Limited warranty - 3 years , Limited warranty - lamp - 1 year
- Sound Emission
- 35 dB
- Sound Emission (Economic Mode)
- 28 dB
