Epson EB 425W - LCD projector - 2500 ANSI lumens - WXGA (1280 x 800) - widescreen
Quicklinx: 7WCHWS00 Mfr#: V11H448041
  • High-Definition Multimedia Interface (HDMI)
High-quality picture
Powered by 3LCD technology, the EB-425W achieves accurate colour reproduction, important in education for natural-looking flags, maps and diagrams. A White and Colour Light Output of up to 2,500 lumens assures a clear picture, even in daylight, while a contrast ratio of 3,000:1 delivers sharp detail.
Interactive lessons
Attach the optional Epson ELP-IU03 interactive module to captivate the class with interactive presentations. The module works with the projector to make any surface interactive - no screen required. Notes or additions can be created and saved with the included digital pen. For a complete solution, the projector also has an optional tailor-made wall mount.
Convenient to control
The EB-425W is compatible with the Epson ELPCB01 Control and Connection Box, which puts Epson projector controls within easy reach at the front of the classroom. It also keeps cables tidy.
Engaging presentations
Presentations can be made more engaging by plugging in the Epson ELP-DC06 USB document camera to show 3D objects close-up, or by using the HDMI input to display high-definition content. The built-in 16W speaker and microphone input ensure students won't ever struggle to hear.
Easy to use
Super-easy to set up and use, the EB-425W features 3-in-1 USB display, so one cable is all that's needed for visuals, audio and mouse control. The picture can be aligned in seconds using the vertical and horizontal keystone correction, which is unique to Epson in the short-throw category. Plus, the projector can be conveniently turned on and off from a wall switch using the direct power on/off function.
Economical
Schools can make savings thanks to the EB-425W's low total cost of ownership. Its Epson E-TORL lamp produces more light using less energy, and lasts 6,000 hours in eco mode. The filter also has a long life of 5,000 hours for years of trouble-free operation. Further reducing costs and maintenance time, the projectors can be connected to a network to enable remote control and monitoring & broadcast images.
  • Short-throw WXGA projector
    This affordable, 2,500-lumen, short-throw projector can be mounted closer to the screen for fewer shadows when presenting.
Epson EB-425W - 3LCD projector - LAN
3LCD projector - 720p
Built-in Devices
Speaker
Brightness
2500 lumens
Brightness (Colour)
2500 lumens
Contrast Ratio
3000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
E-TORL UHE 200 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode ¦ Up to 6000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video LAN
Digital Video Standard
Video Modes
1080p
Video Output
RGB
Speakers
Speaker(s) - internal
283 Watt
34.5 cm x 27.7 cm x 10.5 cm
3.8 kg
3-year warranty
Built-in Devices
Speaker
Projector
Brightness
2500 lumens
Contrast Ratio
3000:1
Image Size
102 cm - 295 cm
Throw Ratio
0.48 - 0.65:1
Digital Zoom Factor
1.35x
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
E-TORL UHE 200 Watt
Bulb life cycle
OSD Languages
Hebrew, Hungarian, Czech, Croatian, Slovenian, Slovak, Ukrainian, English, German, French, Italian, Polish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian
EPSON 3LCD technology
Lens
Focus Type
Manual
Lens Aperture
F/1.8
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-15 / +15
Horizontal Keystone Correction
-15 / +15
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
1080p
LAN and Wireless Image Transferring Protocols
Wired LAN
Video Output
Analogue Video Signal
RGB
Speakers
Internal
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
Input Device
External
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x microphone - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A
Wireless remote control
Security Features
Security lock slot (cable lock sold separately), password protection
283 Watt
Power Consumption Operational (Standby)
0.39 Watt
34.5 cm
27.7 cm
10.5 cm
3.8 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year
Sound Emission
35 dB
28 dB
