The Epson EB-2265U Office / Desktop uses LCD technology to product a 1920*1200 resolution image with a brightness of 5500 and 15000:1 contrast ratio.
Outstanding quality display of up to 300 inches
Full HD resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. Versatile connectivity guarantees sharper and clearer presentations delivered on a scalable image size of up to 300 inches. -
HDBaseT connectivity
The EB-2265U offers a wide range of connectivity options, including HDBaseT, screen mirroring, wireless LAN and two HDMI inputs. HDBaseT provides Full HD video, audio and Ethernet connectivity via one cable to enable efficient control from 100m away. -
Home screen
The home screen offers quick and easy access to a variety of useful functions, such as connection sources. Wireless connections can also be made easily using the information on the screen. -
Gesture Presenter
Change slides by simply moving your hand, making even smarter presentations a reality by liberating the user from their remote control or mouse. -
Auto Power On
The projector will start-up automatically upon connecting an HDMI, VGA, or USB cable, meaning you no longer have to use the power button on the remote control. -
Value-added flexibility
The Multi-PC projection software bundled with the EB-2265U makes it possible to connect up to 50 computers and partition the screen for split-screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
- Epson EB-2265U - LCD projector - 802.11n wireless / LAN / Miracast - white
- LCD projector - 1080p
- White
- Brightness (White)
- 5500 lumens
- Brightness (Colour)
- 5500 lumens
- Contrast Ratio
- 400:1 / 15000:1 (dynamic)
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- 300 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, composite video IEEE 802.11n wireless / LAN / Miracast
- Speakers
- Speaker(s) - integrated
- Power
- AC 230V (50 - 60 Hz)
- 450 Watt
- 37.7 cm x 29.1 cm x 11 cm
- 4.9 kg
- 3-year warranty
- Networking
- 802.11b/g/n, Ethernet
- Enclosure Colour
- White
Projector
- 5500 lumens
- 5500 lumens
- Brightness (Reduced)
- 3800 lumens
- Contrast Ratio
- Image Size
- 127 cm - 762 cm
- Projection Distance
- 1.5 m - 9 m
- Throw Ratio
- 1.38 - 2.28:1
- Digital Zoom Factor
- 1.6x
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Colour Support
- Bulb type
- 300 Watt
- Bulb life cycle
- sRGB colour profile, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, instant on/off
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.5-2.0
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, DisplayPort, composite video
- LAN and Wireless Image Transferring Protocols
- IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n, Miracast
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort - 20 pin DisplayPort , 2 x HDMI - 19 pin HDMI Type A , 1 x HDBaseT - RJ-45
- Included Accessories
- Wireless remote control, wireless LAN unit
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Power Source
- AC
- Voltage Required
- 450 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
- 37.7 cm
- 29.1 cm
- 11 cm
- 4.9 kg
- Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 40 °C
- 20 - 80%
- Sound Emission
- 39 dBA
- Sound Emission (Economic Mode)
- 29 dBA
Epson ELPMB23 Projector Mount | In Stock | £109.44 |
