Up to 280-inch display and outstanding quality
HD-ready WXGA resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer content, even at the maximum image size of 280 inches.
Simple set-up and connectivity
Offers auto power-on and an array of connectivity options including two HDMI connections and built-in wireless LAN connectivity to stream content from laptops or mobile devices. Compatible with iProjection software for easy connectivity and content sharing.
Keep costs down
Project for longer with improved reliability and a longer lamp life of up to 12,000 hours in eco mode.
Home screen
The home screen offers quick and easy access to a variety of useful functions, such as choosing connection sources. Wireless connections can also be made easily using the information on screen.
Value added flexibility
The Multi-PC projection software bundled with the EB-2142W makes it possible to connect with up to 50 computers and partition the screen for split-screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
Affordable business projector
Deliver great presentations with a display solution that offers a great brightness of 4,200 lumens and a scalable image size of up to 280 inches.
- Epson EB-2142W - 3LCD projector - LAN - white
- 3LCD projector - 720p
- White
- Built-in Devices
- Speaker
- Brightness (White)
- 4200 lumens
- Brightness (Colour)
- 4200 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- 230 Watt
- Bulb life cycle
- Up to 6000 hour(s) - normal mode , Up to 12000 hour(s) - economic mode
- Video Input
- LAN
- Speakers
- Speaker(s) - integrated
- Power
- AC 230V (50 - 60 Hz)
- 331 Watt
- 30.9 cm x 28.2 cm x 9 cm
- 3.1 kg
- 3-year warranty
- Built-in Devices
- Speaker
- Networking
- Ethernet
- Enclosure Colour
- White
Projector
- 4200 lumens
- 4200 lumens
- Brightness (Reduced)
- 2400 lumens
- Contrast Ratio
- 15000:1 (dynamic)
- Image Size
- 74 cm - 711 cm
- Projection Distance
- 0.9 m - 8.5 m
- Throw Ratio
- 1.38 - 2.24:1
- Digital Zoom Factor
- 1.6x
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz
- Bulb type
- 230 Watt
- Bulb life cycle
- sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, EPSON 3LCD technology, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.51-1.99
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -20 / +20
Video Input
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 16 Watt
- Speakers
- 1 x mixed channel
- 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - RCA x 2 , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x microphone input - mini-phone 3.5 mm
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, Wireless LAN Lock
- Power Source
- AC
- Voltage Required
- 331 Watt
- Power Consumption Stand by
- 2 Watt
- Software Included
- EasyMP Multi PC Projection
- 30.9 cm
- 28.2 cm
- 9 cm
- 3.1 kg
- Limited warranty - 3 years / 8000 hours , Limited warranty - lamp - 1 year / 1000 hours
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dBA
- Sound Emission (Economic Mode)
- 28 dBA
Epson Wireless Adaptor LAN B/G/N | In Stock | £99.78 |
