Convenient use
The Epson EB-1940W combines high-quality output, value-added features and affordability, into a compact and portable projector. It is perfect for corporate or educational use, as it can be easily installed in meeting rooms or used portably from a desktop.
High quality picture
Utilising Epson's 3LCD technology to ensure clearly projected images, the EB-1940W produces vivid, natural colours and an equally high White and Colour Light Output, even in daylight.
The EB-1940W boasts a DisplayPort connector, allowing you to show high definition audio and video content with ease.
Enhanced productivity
Productivity can be greatly increased with a range of features available with the EB-1940W, such as Quick Corner.
- Epson EB-1940W - 3LCD projector - LAN
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet, Fast Ethernet
- Brightness
- 4200 lumens
- Brightness (Colour)
- 4200 lumens
- Contrast Ratio
- 3000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- 245 Watt
- Bulb life cycle
- Up to 2500 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, composite video, component video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60), LAN
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 720i, 526i, 526p
- Video Output
- RGB
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 337 Watt
- 37.7 cm x 10.8 cm x 27.1 cm
- 3.7 kg
- 3-year warranty
- 3LCD projector
- Built-in Devices
- Speaker
- Networking
- Ethernet
- Data Link Protocol
Projector
- Brightness
- 4200 lumens
- 4200 lumens
- Brightness (Reduced)
- 2910 lumens
- Contrast Ratio
- 3000:1
- Image Size
- 74 cm - 711 cm
- Projection Distance
- 0.8 m - 13.9 m
- Throw Ratio
- 1.38 - 2.24:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Display Format
- 1,024,000 pixels (1,280 x 800) x 3
- Bulb type
- 245 Watt
- Bulb life cycle
- Auto Vertical Keystone, EPSON 3LCD technology
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.51-1.99
- Zoom Type
- Manual
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Video Output
- Analogue Video Signal
- RGB
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
Input Device
- External
- 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A , 1 x HDMI input - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9)
- Included Accessories
- Wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), password protection, control panel lock, security bar
- Voltage Required
- 337 Watt
- Power Consumption Operational (Standby)
- 0.44 Watt
- Software Included
- Drivers & Utilities, EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
- 37.7 cm
- 10.8 cm
- 27.1 cm
- 3.7 kg
- Limited warranty - 3 years - carry-in , Limited warranty - lamp - 1 year
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 29 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
C2G 5m Select High Speed HDMI with Ethernet | In Stock | £28.49 |
