Epson EB-1795F 3,200 lumens, 1080p Full HD 3LCD portable
Quicklinx: DCPNWS00 Mfr#: V11H796041
Perfect for people who are constantly on the move and frequently make presentations at customer sites, this ultra-mobile projector offers a winning combination of ultra-slim lightweight design, exceptional image quality and advanced functionality. With traditional wired and built-in wireless connectivity, time-saving set-up plus a range of advanced features, it's the ideal tool for polished presentations.
  • True portability
    The ultra-slim form factor and lightweight design makes this the ideal projector for anyone on the move. A carry case is included and the projector fits easily into a standard laptop bag.
  • Exceptional image quality
    Enjoy superb image quality, impressive natural colors with an equally high white and color light output of 3,200 lumens thanks to Epson's 3LCD technology. True Colors technology delivers a faithful reproduction of colors as they are meant to be and, with a 10,000:1 contrast ratio, projected images are crisp and clear.
  • A truly big-screen experience
    The display solutions use the advanced technology to allow content sharing and impressive true color presentations on scalable screen sizes of up to 300 inches with a Full HD resolution.
  • Easy set-up
    Automatic vertical and horizontal keystone correction and Screen Fit makes it easy to set up the projector almost anywhere. The short throw ratio projects a large image from a shorter distance so that all meeting participants can be seated behind the projector as the front exhaust directs heat away from them. Auto Power On turns the projector on when it detects signal input, and NFC makes it easy to connect to mobile devices using the built-in Wi-Fi connectivity.
  • Connectivity and flexibility
    The EB-1795F has wireless connectivity as standard to give you enhanced freedom and flexibility. NFC makes it easy to connect the projector to a smartphone or tablet device and project wirelessly. MHL support makes it easy to show high-quality video and audio content from mobile devices, while charging them at the same time.
Epson EB-1795F - 3LCD projector - portable - 802.11n wireless / NFC / Miracast - black, white
3LCD projector - 1080p
Black, white
Brightness (White)
3200 lumens
Brightness (Colour)
3200 lumens
Contrast Ratio
10000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
214 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 7000 hour(s) - economic mode
Video Input
RGB, composite video IEEE 802.11n wireless / NFC / Miracast
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
295 Watt
29.2 cm x 21.3 cm x 4.4 cm
1.83 kg
802.11b/g/n, NFC
Enclosure Colour
Black, white
Projector
Brightness (White)
3200 lumens
Brightness (Colour)
3200 lumens
Brightness (Reduced)
1900 lumens
Contrast Ratio
10000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
0.7 m - 8.2 m
Throw Ratio
1.04 - 1.26:1
Resolution
Full HD - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
Bulb type
214 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Dynamic Mode, Theater Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.7
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, MHL
LAN and Wireless Image Transferring Protocols
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, NFC (Near Field Communication), Miracast
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x composite video input - RCA
Carrying case, wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
Power Source
AC
295 Watt
Power Consumption Stand by
0.34 Watt
Software Included
EasyMP Multi PC Projection
29.2 cm
21.3 cm
4.4 cm
1.83 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 1 year / 1000 hours
5 °C
20 - 80%
Sound Emission
39 dBA
30 dBA
