Ideal for presenting on-location
Fast set-up and shut down is easy with the EB-1751's quick-start-up and instant-off functions and means you don't have to wait for the projector to warm up or cool down. The lightweight, slim design makes this projector effortless to transport around in its comfortable carry case.
Straight images every time
You can ensure that you always have a straight image, no matter the projector's angle. Epson's automatic vertical keystone correction and manual horizontal keystone correction helps align images during set-up.
Superb quality
This projector is enhanced by Epson's 3LCD technology to provide superb quality images. An equally high White and Colour Light Output of up to 2,600 lumens means you can present during the day without having to switch off lights and, with HDMI input, high-definition content can be shown with maximum clarity.
Portable business projector
Part of Epson's business projector range that's packed full of intelligent features for fast, portable presenting.
- Epson EB-1751 - 3LCD projector - portable
- 3LCD projector
- Brightness
- 2600 lumens
- Brightness (Colour)
- 2600 lumens
- Contrast Ratio
- 2000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- UHE 230 Watt
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 1080p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 304 Watt
- 21 cm x 29.2 cm x 4.4 cm
- 1.7 kg
- 3-year warranty
- 3LCD projector
Projector
- Brightness
- 2600 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.7 m - 8.8 m
- Throw Ratio
- 1.19 - 1.43:1
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Bulb type
- UHE 230 Watt
- Bulb life cycle
- Controls & Adjustments
- Mute
- OSD Languages
- Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Slovak, Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Catalan
- sRGB colour profile, Blackboard Mode, instant shutdown, Auto Vertical Keystone, EPSON 3LCD technology, Whiteboard Mode, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.58-1.7
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
- 1080p
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 1 Watt
- Speakers
- 1 x mixed channel
Input Device
- External
- 1 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type A , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type B
- Included Accessories
- Carrying case, wireless remote control
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x USB cable
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Voltage Required
- 304 Watt
- Power Consumption Operational (Standby)
- 0.44 Watt
- 21 cm
- 29.2 cm
- 4.4 cm
- 1.7 kg
- Limited warranty - 3 years , Limited warranty - lamp - 1 year / 1000 hours
- Sound Emission
- 40 dB
- Sound Emission (Economic Mode)
- 30 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
