Epson EB-1751 LCD 2600 Lumens Projector
Quicklinx: 8MFWWS00 Mfr#: V11H479041
Ideal for presenting on-location
Fast set-up and shut down is easy with the EB-1751's quick-start-up and instant-off functions and means you don't have to wait for the projector to warm up or cool down. The lightweight, slim design makes this projector effortless to transport around in its comfortable carry case.
Straight images every time
You can ensure that you always have a straight image, no matter the projector's angle. Epson's automatic vertical keystone correction and manual horizontal keystone correction helps align images during set-up.
Superb quality
This projector is enhanced by Epson's 3LCD technology to provide superb quality images. An equally high White and Colour Light Output of up to 2,600 lumens means you can present during the day without having to switch off lights and, with HDMI input, high-definition content can be shown with maximum clarity.
  • Portable business projector
    Part of Epson's business projector range that's packed full of intelligent features for fast, portable presenting.
Epson EB-1751 - 3LCD projector - portable
3LCD projector
Brightness
2600 lumens
Brightness (Colour)
2600 lumens
Contrast Ratio
2000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
UHE 230 Watt
Bulb life cycle
Up to 4000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
Video Input
RGB, composite video (NTSC, SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, PAL 60)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
1080p
Speakers
Speaker(s) - integrated
304 Watt
21 cm x 29.2 cm x 4.4 cm
1.7 kg
3-year warranty
3LCD projector
Projector
Brightness
2600 lumens
Contrast Ratio
2000:1
Image Size
76 cm - 762 cm
Projection Distance
0.7 m - 8.8 m
Throw Ratio
1.19 - 1.43:1
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Bulb type
UHE 230 Watt
Bulb life cycle
Controls & Adjustments
Mute
OSD Languages
Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Slovak, Ukrainian, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Catalan
sRGB colour profile, Blackboard Mode, instant shutdown, Auto Vertical Keystone, EPSON 3LCD technology, Whiteboard Mode, Direct Power On, Direct Power Off, Dynamic Mode, Theater Mode
Lens
Focus Type
Manual
Lens Aperture
F/1.58-1.7
Zoom Factor
1.2x
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
1080p
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
1 Watt
Speakers
1 x mixed channel
Input Device
External
1 x HDMI input - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type A , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x USB 2.0 - 4 pin USB Type B
Carrying case, wireless remote control
1 x VGA cable - 1.8 m , 1 x USB cable
Security Features
Security lock slot (cable lock sold separately), password protection
304 Watt
Power Consumption Operational (Standby)
0.44 Watt
21 cm
29.2 cm
4.4 cm
1.7 kg
Limited warranty - 3 years , Limited warranty - lamp - 1 year / 1000 hours
Sound Emission
40 dB
30 dB
8MFW C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
