Bring interactivity to any meeting room with our latest ultra-short-throw projector, featuring finger-touch and dual pen capability, a high brightness level of 4,400 lumens, Full HD WUXGA resolution and remote multi-location connectivity. The ultra-short-throw EB-1460Ui is designed to present a scalable screen size of up to 100 inches to deliver the requirements of any business working environment.
Up to 100-inch display and outstanding quality
Full HD WUXGA resolution combined with Epson’s 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity also means that the audience benefits from sharper and clearer content displayed in any meeting room environment.
All in one office solution
This interactive meeting room solution combines the benefits of flipcharts, whiteboards and conventional screens into one unified meeting room solution. Meeting participants can view and annotate whiteboard content from a range of smart devices, without the need for any special application and this ensures information remains secure with the ability to apply passwords to meetings and notes.
Finger-touch and dual pen
Use your fingers to annotate directly on the screen. Epson's interactive pens are now even more responsive and easy to use. With the new dual pens, colleagues can work simultaneously using different pen attributes.
Sliding split screen
Combine two sources and project, such as multi-source video conference and presentation, to optimise interaction.
Wireless & Screen Mirroring connectivity
Share content easily from a range of smart devices using the iProjection App and screen mirroring feature. The same content can be annotated remotely, with up to four networked projection systems connected at the same time.
Robust connectivity
With a wide array of interfaces including HDMI, VGA, USB 2.0, and RJ-45, the Epson EB-1460Ui ensures seamless connection to a variety of devices, making it ideal for diverse presentation environments. -
High-quality audio
Integrated 16 W speaker delivers clear, powerful sound, enhancing the audio experience for presentations and multimedia content without the need for external speakers. -
Wireless presentation
Offers advanced wireless connectivity options, including IEEE 802.11b/g/n and Miracast, allowing for easy and efficient sharing of presentations and multimedia from multiple devices. -
Bright and vivid visuals
Boasting 4400 lumens of brightness and a dynamic contrast ratio of 16000:1, the projector delivers sharp, vibrant images even in well-lit rooms. -
Flexible installation
Features such as manual focus, horizontal and vertical keystone correction, and a throw ratio of 0.27 - 0.37:1 enable versatile placement and easy setup in any room size.
 - Epson EB-1460Ui - 3LCD projector - 802.11b/g/n wireless / LAN / Miracast - white
 - 3LCD projector - 1080p
 - White
- Built-in Devices
 - Speaker
- Brightness (White)
 - 4400 lumens
- Brightness (Colour)
 - 4400 lumens
- Contrast Ratio
 - 300:1 / 16000:1 (dynamic)
- Resolution
 - WUXGA (1920 x 1200)
- Native Aspect Ratio
 - 16:10
- Colour Support
 - 1.07 billion colours
- Video Input
 - RGB, S-Video IEEE 802.11b/g/n wireless / LAN / Miracast
- Speakers
 - Speaker(s) - integrated
- Power
 - AC 230V (50 - 60 Hz)
 - 490 Watt
 - 47.4 cm x 44.7 cm x 13 cm
 - 8.5 kg
 - 3-year warranty
- Built-in Devices
 - Speaker
- Networking
 - 802.11b/g/n, Ethernet
- Enclosure Colour
 - White
Projector
 - 4400 lumens
 - 4400 lumens
- Brightness (Reduced)
 - 2700 lumens
- Contrast Ratio
- Image Size
 - 178 cm - 254 cm
- Projection Distance
 - 0.4 m - 0.6 m
- Throw Ratio
 - 0.27 - 0.37:1
- Digital Zoom Factor
 - 1.35x
- Resolution
 - WUXGA - WUXGA (1920 x 1200)
 - 16:10
- Colour Support
 - sRGB colour profile, Blackboard Mode, EPSON 3LCD technology, Whiteboard Mode, Split Screen, Automatic Brightness Adjustment, Dynamic Lamp Control, Dynamic Mode, Theater Mode, Auto Calibration
Lens
- Focus Type
 - Manual
- Lens Aperture
 - F/1.6
- Keystone Correction Direction
 - Horizontal, vertical
- Vertical Keystone Correction
 - -3 / +3
- Horizontal Keystone Correction
 - -3 / +3
Video Input
- Analogue video Signal
 - RGB, S-Video
- Video Interfaces
 - VGA, HDMI, S-Video, MHL
- LAN and Wireless Image Transferring Protocols
 - IEEE 802.11b, IEEE 802.11g, wired LAN, IEEE 802.11n, Miracast
Speakers
 - Integrated
- Sound Output Mode
 - Mono
- Output Power / Channel
 - 16 Watt
- Speakers
 - 1 x mixed channel
 - 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x HDMI input - 19 pin HDMI Type A , 2 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x microphone , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x Sync in , 1 x Sync out , 1 x DVI-D output
- Included Accessories
 - Wireless remote control, control pad, pen case, finger touch unit, interactive pens
- Cables Included
 - 1 x USB cable
- Mounting Kit
 - Included
- Security Features
 - Security lock slot (cable lock sold separately), password protection
- Power Source
 - AC
- Voltage Required
 - 490 Watt
- Power Consumption Stand by
 - 0.5 Watt
- Software Included
 - Epson Easy Interactive Tools, EasyMP Network Projection, EasyMP Monitor, EasyMP Multi PC Projection
 - 47.4 cm
 - 44.7 cm
 - 13 cm
 - 8.5 kg
 - Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
 - 5 °C
 - 35 °C
 - 20 - 80%
- Sound Emission
 - 38 dBA
- Sound Emission (Economic Mode)
 - 30 dBA
