Epson Dot Matrix Printer
Quicklinx: 4K6DWS00 Mfr#: C11C638002
Works hard
It might be compact, but this 24-pin, 80-column A4 printer gives a great performance. It's also very reliable and cost-effective to run.
Easy to use
The Epson LQ-300+II printer will fit right into your business. It prints up to 4 part forms and has 8 built-in barcode fonts to make your life even easier.
Paper handling
Choose from standard or optional paper handling from top, rear and bottom and print on cut sheet and continuous media.
  • Works hard
  • Easy to use
  • Paper handling
Epson LQ 300+II - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 24 pin - B/W
4.4 kg
Max Media Size
JIS B4 (257 x 364 mm), continuous paper 101.6 mm - 254 mm (width)
Max Media Size (Custom)
257 mm x 559 mm
Print Speed
Up to 225 char/sec - draft , Up to 270 char/sec - draft , Up to 300 char/sec - fast draft , Up to 192 char/sec - condensed , Up to 225 char/sec - condensed , Up to 75 char/sec - letter , Up to 90 char/sec - letter , Up to 128 char/sec - condensed , Up to 150 char/sec - condensed
Max Resolution (B&W)
360 dpi
Parallel, USB, serial
RAM Installed (Max)
32 KB
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Media Type
Envelopes, plain paper, continuous forms
Microsoft Certification
Works with Windows Vista
1-year warranty
36.6 cm x 27.5 cm x 15.9 cm
Printer Type
Workgroup printer - dot-matrix - 24 pin - monochrome
Printer
Print Speed
Up to 225 char/sec - draft - 10 cpi , Up to 270 char/sec - draft - 12 cpi , Up to 300 char/sec - fast draft - 10 cpi , Up to 192 char/sec - condensed - 17 cpi , Up to 225 char/sec - condensed - 20 cpi , Up to 75 char/sec - letter - 10 cpi , Up to 90 char/sec - letter - 12 cpi , Up to 128 char/sec - condensed - 17 cpi , Up to 150 char/sec - condensed - 20 cpi
Wired
360 dpi
Fonts Included
10 x bitmapped , 4 x scalable , 8 x barcode
Barcodes
RAM
RAM Installed (Max)
32 KB
Media Handling
Media Type
Max Media Size
257 mm x 559 mm
Media Sizes
Legal (216 x 356 mm), JIS B4 (257 x 364 mm), continuous paper 101.6 mm - 254 mm (width)
Max Sheets in Multi-Part Form
4
1 x parallel - 36 PIN Centronics , 1 x serial , 1 x USB
MTBF
6,000 hour(s)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Power supply - internal
Frequency Required
50/60 Hz
20 Watt
Limited warranty - 1 year
5 °C
35 °C
10 - 80%
Sound Emission (Operating)
49 dBA
36.6 cm
27.5 cm
15.9 cm
4.4 kg
