The Epson PP-100AP Autoprinter delivers professional prints on CDs, DVDs or BDs. The PP-100AP processes up to 95 discs per hour and is therefore ideally suited for quick and efficient large batch production of professionally designed digital media. The new Discproducer delivers high quality printing while keeping costs low.
CDs, DVDs and Blu-ray discs are frequently used in the entertainment and imaging industries but there also is an increasing need for businesses, agencies and public organisations, who need discs with a professional look and finish for their digital handouts. Today, marketing departments prefer sending images and movies on CDs and DVDs to customers and partners.
The fully automatic Autoprinter has four trays, allowing up to 100 discs in two trays to be processed continuously in one print run. It combines superb print quality and convincing speed. The Epson PP-100AP processes up to 95 discs per hour in fast printing mode, and 50 discs in photo quality mode. If you need to print higher volumes-for example, when duplicating discs professionally-the system can be scaled to match your requirements: you can control up to six Epson PP-100 AP Autoprinters from one computer and process up to 570 fully printed discs (45 mm - 116 mm) per hour.
The sealed printing system is protected against dust and relies on the built-in AcuGrip mechanism designed for a long lifespan of over 100,000 printed media. This way, it even meets the challenging needs of professional disc producers. Using six high capacity individual ink cartridges the PP-100AP achieves an incredible print capacity of over 1,000 prints per set of ink cartridges. To help you work more efficiently it comes with the intuitive software Epson Total Discmaker.
Fast
With the PP-100AP, up to 50 media per hour can be printed in brilliant photo quality. If faster printing is more important to you, then the rate can even be increased to as much as 95 media per hour. -
Print capacity
Epson makes mass printing easy. Up to six PP-100APs can be controlled in parallel from one PC. In this way, you can increase your print capacity at each workstation to 300 media per hour with the highest quality setting or 570 media per hour in high-speed mode. -
Long-lasting
The PP-100AP has been designed to have a service life of more than 100,000 discs. The user-friendly maintenance cartridges need to be changed after approx. 30,000, 60,000 and 90,000 discs. This will keep your PP-100AP in top technical condition. The sealed housing which protects against dust and the patented AcuGrip robotic arm also contribute to the exceptionally long service life. -
Photo quality
Epson's Micro Piezo technology with six different colors also offers exceptional quality with large print quantities. Impress your clients with razor-sharp and intensely colored images printed on high gloss, smudge-proof and waterproof media recommended by Epson. -
Economical
Enjoy the benefits of extremely low print costs. The low purchase price of the PP-100AP and the large-volume ink tanks make this possible. One ink set can print the entire surface area of well over 1000 discs. Separate color cartridges minimize your operating costs as only cartridges that are actually empty need to be replenished. -
Effortless ease of use
The Epson Discproducer PP-100AP is just as easy to operate as any office printer. The use of this printer is intuitive, which saves time and leaves you free to concentrate on your day-to-day work.
- Epson Discproducer PP-100AP - CD/DVD printer - colour - ink-jet
- Printer Type
- CD/DVD printer - ink-jet - colour
- 22 kg
- Inkjet Technology
- Epson Micro Piezo
- Ink Palette Supported (Colours)
- 6-ink - cyan, magenta, yellow, black, light cyan, light magenta
- Max Media Size
- CD (120 mm)
- Print Speed
- Up to 1.58 disks/min - colour fast - CD (120 mm) , Up to 1.25 disks/min - colour fast normal - CD (120 mm) , Up to 0.83 disks/min - colour best - CD (120 mm)
- Max Resolution (B&W)
- 1440 dpi
- Max Resolution (Colour)
- 1440 dpi
- Interface
- USB
- Media Type
- DVD discs, CD discs
- Total Media Capacity
- 100 discs
- System Requirements
- Microsoft Windows 2000 Professional SP4 or later, Microsoft Windows XP Professional SP2 or later, Microsoft Windows XP Home Edition SP2 or later, Microsoft Windows 7 Professional, Microsoft Windows 7 Home Premium, Microsoft Windows 7 Ultimate, Microsoft Windows 7 Enterprise, Microsoft Windows Vista Business SP1 or later, Microsoft Windows Vista Ultimate SP1 or later
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 37.7 cm x 46.5 cm x 34.8 cm
- Printer Type
Printer
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 180 nozzles (per cartridge)
- Ink Cartridge Configuration
- 6 individual ink tanks
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB
- 1440 dpi
- 1440 dpi
Media Handling
- Media Type
- Max Media Size
- CD (120 mm)
- Media Sizes
- CD (120 mm)
- Media Thickness Range
- Up to 1.2 mm
- 100 discs
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- TUV, EN 60950, EN55022 Class B, EMC, GOST-R
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- Software Included
- Epson Total Disc Maker
- OS Required
- System Requirements Details
- Windows 2000/XP - Pentium 4 - 1.4 GHz - RAM 512 MB - HD 10 GB , Windows 7/Vista - Pentium 4 - 1.4 GHz - RAM 1 GB
- Limited warranty - 1 year - on-site
- 10 °C
- 35 °C
- 20 - 80%
- 37.7 cm
- 46.5 cm
- 34.8 cm
- 22 kg
