The Epson DFX-9000 is a high print volume printer providing an unprecedented level of speed and reliability for the most demanding business. Its advanced paper handling accommodates a variety of paper types while the standard front and rear push tractors can be switched easily between different types of continuous paper. An optional perforation cutter provides paper finishing capabilities.
- Epson DFX 9000N - printer - B/W - dot-matrix
- Printer Type
- Personal printer - dot-matrix - 9 pin - B/W
- 34 kg
- Max Media Size
- Continuous paper 76.2 mm - 419.1 mm (width)
- Max Media Size (Custom)
- 419 mm
- Print Speed
- Up to 1550 char/sec - max speed , Up to 1450 char/sec - max speed , Up to 1320 char/sec - draft , Up to 1320 char/sec - draft , Up to 330 char/sec - near letter , Up to 330 char/sec - near letter
- Max Resolution (B&W)
- 240 x 144 dpi
- Interface
- Parallel, USB, LAN, serial
- RAM Installed (Max)
- 128 KB
- Barcodes
- Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
- Media Type
- Labels, continuous forms
- Networking
- Print server - Ethernet, Fast Ethernet
- Power
- AC 120/230 V
- Microsoft Certification
- Works with Windows Vista
- 1-year warranty
- 70 cm x 37.8 cm x 36.3 cm
- Printer Type
- Personal printer - dot-matrix - 9 pin - monochrome
Printer
- Print Speed
- Up to 1550 char/sec - max speed - 10 cpi , Up to 1450 char/sec - max speed - 12 cpi , Up to 1320 char/sec - draft - 10 cpi , Up to 1320 char/sec - draft - 12 cpi , Up to 330 char/sec - near letter - 10 cpi , Up to 330 char/sec - near letter - 12 cpi
- Connectivity Technology
- Wired
- Interface
- 240 x 144 dpi
- Columns
- 136
- Barcodes
RAM
- 128 KB
Media Handling
- Media Type
- Max Media Size
- 419 mm
- Max Sheets in Multi-Part Form
- 10
- Networking
- Print server
- Data Link Protocol
- Expansion Slots
- 1 x Epson Type B
- Connections
- 1 x serial , 1 x parallel , 1 x USB , 1 x LAN - RJ-45
- MTBF
- 20,000 hour(s)
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- CISPR 22 Class B, EN 60950, EN 61000-3-2, EN 61000-3-3, EN55024, UL 60950, CSA 22.2 No. 60950, EN55022 Class B, FCC Part 15 B
- Power Device
- Power supply - internal
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- 185 Watt
- Power Consumption Stand by / Sleep
- 7.5 Watt
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site
- Sound Emission (Operating)
- 58 dBA
- 70 cm
- 37.8 cm
- 36.3 cm
- 34 kg
Epson Black ribbon for DFX-9000 | In Stock | £19.01 |
