Epson Canon Expression Home XP-3205
Quicklinx: HFRNWS00 Mfr#: C11CK66402
13 In Stock
£60.78 ex VAT
£72.93 inc VAT
Sleek and stylish
This affordable model efficiently uses your space combining print, scan and copying facilities in one unit.
Easy to use
With a range of essential and easy to use features, the XP-3205 is flexible with Wi-Fi for printing and scanning wirelessly and Wi-Fi Direct for printing without a wireless network. Its 3.7cm LCD screen makes it easy to copy and print without a computer and double-sided printing reduces paper usage.
Flexible wireless solutions
Print, scan and more, directly from your phone or tablet using the Epson Smart Panel app 1 . Plus, with the Epson Creative Print app, you can print photos directly from Facebook, create greeting cards and more.
Affordable solution
Epson's four-colour Pineapple 604 ink set provides reliable, clear prints with minimal outlay. In addition to reducing your printing costs with affordable, individual inks in standard and XL cartridges.
  • Sleek and stylish
  • Easy to use
  • Flexible wireless solutions
    Print, scan and more, directly from your phone or tablet using the Epson Smart Panel app. Plus, with the Epson Creative Print app, you can print photos directly from Facebook, create greeting cards and more.
  • Affordable solution
  • 3 months free ReadyPrint Flex ink subscription
    For new customers, you can get the first 3 months free when you sign up with code EPSON3. Subscribe and save up to 70% on ink costs with ReadyPrint Flex, and never run out of ink again. Your ink levels are monitored and new inks are sent direct to your door, before you run out!
Epson Expression Home XP-3205 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 10 ppm (mono) / up to 5 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Printing Resolution Class
Scanning
1200 x 2400 dpi
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB, Wi-Fi
AirPrint Enabled
Office Machine Features
Red-eye correction, Photo Enhance
AC 120/230 V (50/60Hz)
37.5 cm x 30 cm x 17 cm
4.3 kg
Enclosure Colour
1-year warranty
Printing Technology
Ink-jet - colour
Display Colour Support
Display Features
LCD display
USB, Wi-Fi
AirPrint Enabled
Enclosure Colour
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
180 nozzles (black), 59 nozzles (per colour)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3 pl
Image Enhancement Technology
Variable Sized Droplet Technology
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Document & Media Handling
Original Type
Sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 90 x 130 mm, 100 x 150 mm, 130 x 180 mm, 130 x 200 mm, 200 x 250 mm, 100 x 148 mm
Supported Envelope Sizes
International C6 (114 x 162 mm), International DL (110 x 220 mm), US No 10 (104.7 x 241.3 mm)
100 sheets
Input tray - 100 sheets , Photo tray - 20 sheets
Speed Details
Printing: up to 33 ppm - B/W (75 gsm plain paper) , Printing: up to 15 ppm - color (75 gsm plain paper) , Printing: 42 sec (10 x 15 cm (4"x6")) - photo , Printing: up to 10 ppm - B/W (ISO/IEC 24734) , Printing: up to 5 ppm - colour (ISO/IEC 24734)
1 x USB
Security Protocols & Features
WEP, WPA-PSK, TKIP, AES, Wi-Fi Direct, WPA2-PSK, WPA3-SAE
Operating System Support
Apple Mac OS X 10.9.5 or later, Windows 10 (32/64-bits), Windows 11, MS Windows 7 (32/64 bits), Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), MS Windows Vista (32/64 bits), MS Windows XP 32-bit Edition SP3 or later, MS Windows XP Professional x64 Edition SP2, macOS 11
Software Included
Epson Photo+, EPSON Scan 2
12 Watt
Power Consumption Standby
4.8 Watt
Power Consumption Sleep
0.7 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
Limited warranty - 1 year - carry-in
37.5 cm
30 cm
17 cm
4.3 kg
Shipping Width
25 cm
Shipping Depth
39.5 cm
Shipping Height
44.5 cm
Shipping Weight
5.43 kg
Sound Emission
38 dBA (operating)
Type: Printer / copier / scanner
Functionality: Scanner
Functionality: Copier
Functionality: Printer
Max Paper Size: A4 (210 x 297 mm)
Brand: Epson
