Fast, professional-quality printing: The series prints up to 28 pages per minute, so there’s no waiting around for large print jobs. And there’s no compromise on quality with a professional print resolution of 1200x1200dpi.
Low cost of ownership: Your cost per page is optimised thanks to high capacity toner cartridges. Epson’s toner cartridge return programme and the AcuLaser MX20DN series’ ENERGY STAR qualified power efficiency further reduce your bills and minimise environmental impact.
Effortless integration: Fitting easily into your IT environment, the AcuLaser MX20DN series comes with network connectivity built-in, plus USB Host and numerous emulations.
Advanced scan-to functions for sharing scanned documents smoothly (Scan-to USB Host, Email, SMB and Event Manager support)
Model configuration
C11CA95001 Epson AcuLaser MX20DN - Main model
C11CA95001BY Epson AcuLaser MX20DTN (220v/240v) - Main Model + one additional paper tray
C11CA95011 Epson AcuLaser MX20DNF - Main model
C11CA95011BY Epson AcuLaser MX20DTNF (220v/240v) - Main Model + one additional paper tray
The series prints up to 28 pages per minute, so there's no waiting around for large print jobs. And there's no compromise on quality with a professional print resolution of 1200x1200dpi. -
Your cost per page is optimised thanks to high capacity toner cartridges. Epson's toner cartridge return programme and the AcuLaser MX20DN series' ENERGY STAR qualified power efficiency further reduce your bills and minimise environmental impact. -
- Epson AcuLaser MX20DTN - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 20000 impressions
- Max Copying Speed
- Up to 28 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 28 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Scanning
- 600 x 600 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, plain paper, labels
- Standard Media Capacity
- 550 sheets
- Max Media Capacity
- 800 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- Power
- AC 230 V
- 49.4 cm x 43 cm x 44.8 cm
- 18.4 kg
- 1-year warranty
- Copier Type
- Digital
- Laser - monochrome
- 20000 impressions
- Interface
- Standard Memory
- 256 MB 256 MB
- Max Supported Memory
- 512 MB 512 MB
Copying
- Max Copying Speed
- Up to 28 ppm
- Max Document Enlargement
- 200%
- Max Document Reduction
- 50%
Printing
- Up to 28 ppm
- First Print Out Time B/W
- 6 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 210 x 330 mm, 215.9 x 266.7 mm, 215.9 x 330.2 mm
- 550 sheets
- 800 sheets
- 50 sheets
- 150 sheets
- 2 x input tray - 250 sheets - Legal (216 x 356 mm) , ADF - 50 sheets - Legal (216 x 356 mm) , Bypass tray - 50 sheets
- Speed Details
- Copying: up to 28 ppm (A4) - B/W , Printing: up to 28 ppm (A4) - B/W
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- Network Protocols
- TCP/IP, AppleTalk, IPP, LPR/LPD
- Operating System Support
- MS Windows XP, MS Windows 2000, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008
- Voltage Required
- AC 230 V
- Limited warranty - 1 year - on-site
- 49.4 cm
- 43 cm
- 44.8 cm
- 18.4 kg
- Sound Emission
- 47 dBA (idle) / 68.9 dBA (operating)
- 10 °C
- 32.5 °C
- 15 - 80%
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.08 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £19.26 |
