Epson AcuLaser MX20DTN A4 Mono Laser Multifunction Printer
Quicklinx: 7YB6WS00 Mfr#: C11CA95001BY
Fast, professional-quality printing: The series prints up to 28 pages per minute, so there’s no waiting around for large print jobs. And there’s no compromise on quality with a professional print resolution of 1200x1200dpi.
Low cost of ownership: Your cost per page is optimised thanks to high capacity toner cartridges. Epson’s toner cartridge return programme and the AcuLaser MX20DN series’ ENERGY STAR qualified power efficiency further reduce your bills and minimise environmental impact.
Effortless integration: Fitting easily into your IT environment, the AcuLaser MX20DN series comes with network connectivity built-in, plus USB Host and numerous emulations.
Advanced scan-to functions for sharing scanned documents smoothly (Scan-to USB Host, Email, SMB and Event Manager support)
Model configuration
C11CA95001 Epson AcuLaser MX20DN - Main model
C11CA95001BY Epson AcuLaser MX20DTN (220v/240v) - Main Model + one additional paper tray
C11CA95011 Epson AcuLaser MX20DNF - Main model
C11CA95011BY Epson AcuLaser MX20DTNF (220v/240v) - Main Model + one additional paper tray
  • C11CA95001 Epson AcuLaser MX20DN - Main model
    C11CA95001BY Epson AcuLaser MX20DTN (220v/240v) - Main Model + one additional paper tray.
  • C11CA95011 Epson AcuLaser MX20DNF - Main model
    C11CA95011BY Epson AcuLaser MX20DTNF (220v/240v) - Main Model + one additional paper tray.
Epson AcuLaser MX20DTN - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
20000 impressions
Max Copying Speed
Up to 28 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 28 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Scanning
600 x 600 dpi
Original Size
Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, plain paper, labels
Standard Media Capacity
550 sheets
Max Media Capacity
800 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing)
Connection Availability
USB 2.0, LAN, USB host
AC 230 V
49.4 cm x 43 cm x 44.8 cm
18.4 kg
1-year warranty
Copier Type
Digital
Printing Technology
Laser - monochrome
20000 impressions
Standard Memory
256 MB 256 MB
Max Supported Memory
512 MB 512 MB
Copying
Max Copying Speed
Up to 28 ppm
Up to 600 x 600 dpi
Max Document Enlargement
200%
Max Document Reduction
50%
Automatic Duplexing
Printing
Max Printing Speed
Up to 28 ppm
Automatic Duplexing
First Print Out Time B/W
6 sec
Scanning
Optical Resolution
600 x 600 dpi
Document & Media Handling
Max Original Size
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
220 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 210 x 330 mm, 215.9 x 266.7 mm, 215.9 x 330.2 mm
550 sheets
Max Media Capacity
800 sheets
50 sheets
150 sheets
2 x input tray - 250 sheets - Legal (216 x 356 mm) , ADF - 50 sheets - Legal (216 x 356 mm) , Bypass tray - 50 sheets
Speed Details
Copying: up to 28 ppm (A4) - B/W , Printing: up to 28 ppm (A4) - B/W
1 x USB 2.0 , 1 x USB host , 1 x LAN
Network Protocols
TCP/IP, AppleTalk, IPP, LPR/LPD
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008
AC 230 V
Limited warranty - 1 year - on-site
49.4 cm
43 cm
44.8 cm
18.4 kg
Sound Emission
47 dBA (idle) / 68.9 dBA (operating)
10 °C
32.5 °C
15 - 80%
7YB6 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.17
