High performance
A high monthly duty cycle of up to 100,000 pages, fast print speed of 32ppm, plus a dot correction function and 1200dpi resolution, mean that the M7000TN is perfect for printing a wide range of business documents.
Easy integration
The M7000TN series offers compatibility for multiple users across many IT networks, making it ideal for sharing across business groups, with network Ethernet connectivity, IPv6, IPsec, PCL6 and PS3 emulations.
Versatile, reliable printing and productivity
The M7000TN allows effortless switching between different paper sizes, from envelopes to A3 documents with the manual paper tray, and two A3 to A4 convertible paper trays, so users won't have to frequently refill with paper.
Optimised printing
Long-lasting toner supplies help optimise cost per page, resulting in a low TCO. This, combined with an ENERGY STAR-qualification for reduced power consumption and environmental impact, along with the Epson cartridge Return and Recycle program means that there is no compromise between cost and ecology.
High performance
Monthly duty cycle of 100,000 pages. -
Easy integration
Gigabit Ethernet, PCL6 and PS3, IPv6, IPSec. -
Compact, easy to use
Holds A3 or A4, extra paper tray. -
Business quality
1200 dpi, dot correction function. -
Eco friendly
Long lasting supplies, duplex option.
- Epson AcuLaser M7000TN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- Media Size Class
- A3/Ledger
- Max Media Size
- A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
- Max Resolution (B&W)
- 1200 dpi
- Interface
- USB, Gigabit LAN
- Processor
- 288 MHz
- RAM Installed (Max)
- 64 MB (320 MB)
- Language Simulation
- PCL 5E, PostScript 3, EPSON ESC/P 2, EPSON FX, PCL 6, EPSON ESC/P, PDF 1.6
- Media Type
- Envelopes, plain paper
- Total Media Capacity
- 880 sheets
- Media Handling
- 150-sheet multipurpose tray, 500-sheet input tray, 230-sheet input tray
- Monthly Duty Cycle (max)
- 100000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - internal
- Printer Features
- Optional duplex
- System Requirements
- Linux, Microsoft Windows Server 2008 R2, Apple MacOS X 10.4.11 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- 1-year warranty
- 51.8 cm x 41.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB, Gigabit LAN
- 1200 dpi
- First Print Out Time B/W
- 8.5 sec
- Printer Features
- Optional duplex
- Media Handling
- Processor
- 288 MHz
RAM
- 64 MB / 320 MB (max)
Media Handling
- Media Type
- Media Size Class
- A3/Ledger
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), F4, C5 (162 x 229 mm), C6 (114 x 162 mm)
- Media Weight
- 60 g/m² - 216 g/m²
- 880 sheets
- Media Feeders
- 1 x automatic - 150 sheets , 1 x automatic - 230 sheets , 1 x automatic - 500 sheets
- Max Media Capacity
- 1380 sheets
- Output Trays Capacity
- 230 sheets
Duty Cycle
- 100000 pages
- Networking
- Print server - internal
- Data Link Protocol
- TCP/IP, AppleTalk, NetBEUI/NetBIOS, LPR/LPD, FTP, BOOTP, DHCP, DDNS
- Remote Management Protocol
- SNMP, IPP, HTTP
- IPsec
- Expansion Slots
- Memory
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black)
- EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 544 Watt
- Power Consumption Stand by / Sleep
- 82 Watt
- Software Included
- Drivers & Utilities, EPSON Web-to-Page, EpsonNet Print, EpsonNet Config
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 5 °C
- 35 °C
- 15 - 85%
- Sound Emission (Idle)
- 33 dB
- Sound Emission (Operating)
- 54 dB
- 51.8 cm
- 41.5 cm
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.03 |
