Epson AcuLaser M7000N A3 Mono Laser Printer
Quicklinx: 8MJ5WS00 Mfr#: C11CB61011BY
High performance
A high monthly duty cycle of up to 100,000 pages, fast print speed of 32ppm, plus a dot correction function and 1200dpi resolution, mean that the M7000N is perfect for printing a wide range of business documents.
Easy integration
The M7000N series offers compatibility for multiple users across many IT networks, making it ideal for sharing across business groups, with network Ethernet connectivity, IPv6, IPsec, PCL6 and PS3 emulations.
Versatile, reliable printing and productivity
The M7000N allows effortless switching between different paper sizes; from envelopes to A3 documents with the manual paper tray, and A3 to A4 documents with the standard convertible paper casette.
Optimised printing
Long-lasting toner supplies help optimise cost per page, resulting in a low TCO. This, combined with an ENERGY STAR-qualification for reduced power consumption and environmental impact, along with the Epson cartridge Return and Recycle program means that there is no compromise between cost and ecology.
  • High performance
  • Easy integration
  • Versatile, reliable printing and productivity
  • Optimised printing
Epson AcuLaser M7000N - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
21 kg
Media Size Class
A3/Ledger
Max Media Size
A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
Print Speed
Up to 32 ppm - B/W
Max Resolution (B&W)
1200 dpi
USB, Gigabit LAN
288 MHz
RAM Installed (Max)
64 MB (320 MB)
Language Simulation
PCL 5E, PostScript 3, EPSON ESC/P 2, EPSON FX, PCL 6, EPSON ESC/P, PDF 1.6
Media Type
Envelopes, plain paper
Total Media Capacity
380 sheets
Media Handling
150-sheet multipurpose tray, 230-sheet input tray
Monthly Duty Cycle (max)
100000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - internal
Printer Features
Optional duplex
Linux, Microsoft Windows Server 2008 R2, Apple MacOS X 10.4.11 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
Microsoft Certification
Compatible with Windows 7
1-year warranty
51.8 cm x 41.5 cm x 33.3 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Up to 32 ppm - B/W
Built-in Devices
Status LCD
Wired
USB, Gigabit LAN
1200 dpi
First Print Out Time B/W
8.5 sec
Language Simulation
Printer Features
Optional duplex
Media Handling
288 MHz
RAM
RAM Installed (Max)
64 MB / 320 MB (max)
Media Handling
Media Type
Media Size Class
A3/Ledger
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), F4, C5 (162 x 229 mm), C6 (114 x 162 mm)
Media Weight
60 g/m² - 216 g/m²
380 sheets
Media Feeders
1 x automatic - 150 sheets , 1 x automatic - 230 sheets
Max Media Capacity
1380 sheets
Output Trays Capacity
230 sheets
Duty Cycle
100000 pages
Print server - internal
Network / Transport Protocol
TCP/IP, AppleTalk, NetBEUI/NetBIOS, LPR/LPD, FTP, BOOTP, DHCP, DDNS
Remote Management Protocol
SNMP, IPP, HTTP
Security Protocols & Features
IPsec
Expansion Slots
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black)
EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1
Power supply - internal
Frequency Required
50/60 Hz
544 Watt
Power Consumption Stand by / Sleep
82 Watt
Software Included
Drivers & Utilities, EPSON Web-to-Page, EpsonNet Print, EpsonNet Config
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site
5 °C
35 °C
15 - 85%
Sound Emission (Idle)
33 dB
Sound Emission (Operating)
54 dB
51.8 cm
41.5 cm
33.3 cm
21 kg
8MJ5 C2G 5m USB 2.0 A/B Cable - Black In Stock £5.08
8MJ5 C2G 12m USB 2.0 A/A Active Extension Cable In Stock £19.26
