Epson Aculaser M4000TN Mono Laser Printer
Quicklinx: 7DGSWS00 Mfr#: C11CA10001BY
High-speed, low-cost A4 monochrome laser for medium and large workgroups - High volume, low cost printing, producing first-rate results at a 43 pages per minute with the first page printed in 8 seconds. Complete with standard networking, this versatile printer meets the broad range of printing requirements for the office. With a large LCD screen, access to functions is both clear and simple.
Transform and increase your business output with this high-end, hard-working network A4 mono laser. - The clarity of the 1200 dpi resolution guarantees a consistent, speedy result every time. The combination of high-yield toners and a unit that fulfils a high-level paper output means that it works better for longer. Designed to enhance and improve your business efficiency, models and options include; duplex, additional paper cassettes, stacker, extra memory plus advanced solutions.
Custom-built for high duty use - High-yield toners and standard 700 sheet paper capacity expandable to 1,800 sheets ensure dependability, reliablility and peace of mind.
Great results and superb value every time - Combine high-performance mono printing with a low-cost per page plus unbeatable discounts available on returned toners
Supports standard printer languages - Integrates easily into your existing IT environment with genuine Adobe PostScript 3 and PCL as standard
Return Cartridges for a lower cost per page - AcuLaser M4000 series Return toner cartridges provide customers with a lower priced toner cartridge on the agreement that the empty cartridge will be returned via Epson's free toner return program. The Return and Recycle programme is part of Epson's global environmental actions and specifically the (toner) cartridge collection and the recycling scheme.
  • High-speed, low-cost A4 monochrome laser for medium and large workgroups
  • Transform and increase your business output with this high-end, hard-working network A4 mono laser
  • Custom-built for high duty use
  • Great results and superb value every time
    Combine high-performance mono printing with a low-cost per page plus unbeatable discounts available on returned toners.
  • Supports standard printer languages
    Integrates easily into your existing IT environment with genuine Adobe PostScript 3 and PCL as standard.
  • Return Cartridges for a lower cost per page
Epson AcuLaser M4000TN - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
21.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 43 ppm - max speed - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Parallel, USB, LAN
300 MHz
RAM Installed (Max)
64 MB (576 MB)
Language Simulation
PCL 5E, PostScript 3, EPSON ESC/P 2, EPSON FX, PCL 6, EPSON ESC/P, IBM 2391 Plus, IBM 2390 Plus, PDF 1.3
Media Type
Envelopes, transparencies, labels, plain paper, heavy-weight paper, recycled paper
Total Media Capacity
1250 sheets
Media Handling
150-sheet multipurpose tray, 2x 550-sheet input trays
Monthly Duty Cycle (max)
200000 pages
Print server - Ethernet, Fast Ethernet - internal
Printer Features
Optional duplex
Microsoft Certification
Works with Windows Vista
1-year warranty
42.8 cm x 48 cm x 40.4 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
Parallel, USB, LAN
1200 dpi
PostScript Support
Standard
First Print Out Time B/W
8 sec
Language Simulation
Fonts Included
276 x scalable , 13 x bitmapped , 26 x barcode
Printer Features
Optional duplex
Media Handling
300 MHz
RAM
RAM Installed (Max)
64 MB / 576 MB (max)
Slots Qty
2
Empty Slots
2
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76.2 x 127 mm
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 216 g/m²
1250 sheets
Media Feeders
1 x automatic - 150 sheets - Legal (216 x 356 mm) , 2 x automatic - 550 sheets - Legal (216 x 356 mm) , 1 x automatic (optional) - 550 sheets - Legal (216 x 356 mm)
Max Media Capacity
1800 sheets
Output Trays Capacity
500 sheets
Duty Cycle
200000 pages
Print server - internal
Network / Transport Protocol
TCP/IP, AppleTalk, NetBEUI/NetBIOS, LPR/LPD, Bonjour
Expansion Bays
1 (total) / 1 (free) x internal
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 1 x parallel - 36 PIN Centronics , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 20000 pages , 1 x fuser - up to 200000 pages
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, EMC, Laser Class 1, EN 60950-1
Power supply - internal
Frequency Required
50/60 Hz
654 Watt
Power Consumption Stand by / Sleep
77 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site
10 °C
32 °C
15 - 85%
42.8 cm
48 cm
40.4 cm
21.5 kg
