Epson AcuLaser M2300DN
Quicklinx: 791CWS00 Mfr#: C11CB47031BX
Flexible paper handling: Big jobs are no problem for this high-performance printer, which can handle up to 550 sheets using the optional additional paper tray and offers the paper-saving benefit of automatic double-sided printing.
Expandable memory: Adjust the AcuLaser M2300DN's RAM to match the needs of your business by expanding it from 64MB up to 320MB.
Effortless integration: The AcuLaser M23000DN will fit easily into most IT environments. It offers PCL6 support and has both USB and Ethernet interfaces for easy sharing across small workgroups
Save money and the environment: ENERGY STAR qualified power efficiency and Epson’s toner cartridge return programme make this printer better for both the environment and your budget.
  • Flexible paper handling
  • Expandable memory
  • Effortless integration
    The AcuLaser M23000DN will fit easily into most IT environments. It offers PCL6 support and has both USB and Ethernet interfaces for easy sharing across small workgroups.
  • Save money and the environment
    ENERGY STAR qualified power efficiency and Epson's toner cartridge return programme make this printer better for both the environment and your budget.
Epson AcuLaser M2300DN - printer - B/W - laser
Printer Type
Personal printer - laser - B/W
11.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 30 ppm - monochrome - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 dpi
Automatic Duplexing
USB, LAN
300 MHz
RAM Installed (Max)
64 MB (320 MB)
Language Simulation
PCL 5E, EPSON ESC/P 2, EPSON FX, PCL 6, EPSON ESC/P
Total Media Capacity
300 sheets
Media Handling
50-sheet multipurpose tray, 250-sheet paper cassette
Monthly Duty Cycle (max)
20000 pages
Print server - Ethernet, Fast Ethernet
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Server 2008, Apple MacOS X 10.4.11 or later, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
Microsoft Certification
Compatible with Windows 7
1-year warranty
37.8 cm x 39 cm x 25.5 cm
Printer Type
Personal printer - laser - monochrome
Printer
Print Speed
Wired
USB, LAN
1200 dpi
Automatic Duplexing
First Print Out Time B/W
6 sec
Language Simulation
Media Handling
300 MHz
RAM
RAM Installed (Max)
64 MB / 320 MB (max)
Media Handling
Media Size Class
A4/Legal
Max Media Size
70 mm x 148 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), F4
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 220 g/m²
300 sheets
Media Feeders
1 x automatic - 50 sheets - Legal (216 x 356 mm) , 1 x automatic - 250 sheets - Legal (216 x 356 mm)
Max Media Capacity
550 sheets
Output Trays Capacity
250 sheets
Duty Cycle
20000 pages
Print server
Network / Transport Protocol
TCP/IP, AppleTalk, LPR/LPD, FTP, DDNS
Remote Management Protocol
SNMP, IPP, HTTP
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Power supply - internal
Environmental Standards
ENERGY STAR
Limited warranty - 1 year - on-site
10 °C
32.5 °C
15 - 80%
Sound Emission (Idle)
47 dBA
Sound Emission (Operating)
68 dBA
37.8 cm
39 cm
25.5 cm
11.5 kg
