Epson AcuLaser M1200 - printer - B/W - laser
Quicklinx: 6CYNWS00 Mfr#: C11CA71001BY
The AcuLaser M1200 can print up to 20 pages per minute and up to 600dpi for high quality results in black and white - the ideal compact printing solution for desktop use in the office or at home.
With USB and parallel interfaces, the AcuLaser M1200 is compatible with all common operating systems, and with one of the best duty cycles on the personal printer market, it offers excellent reliability to business users.
The AcuLaser M1200 is competitively priced to provide business users with an affordable printing solution. The dedicated EPSON Status Monitor 3 enables users to modify printer preferences and it also provides clear status messages, making it easy to manage and maintain the printer.
(Printer comes with Starter Toner Cartridge)
  • High-performance personal printing
    Combine print speeds of up to 20 ppm with professional quality at up to 600 dpi resolution, for perfect business letters, emails, web pages and more. This compact printer fits easily onto your desktop and is one of the only printers in its class that has parallel and USB interfaces as standard, so it´s easy to connect the Epson AcuLaser M1200 to your computer and use it as your local printer.
  • Reliable, easy to use and maintain
    Enjoy simple, reliable mono business printing with the standard multi-purpose 150-sheet paper tray and a very high duty cycle for desktop usage of up to 15,000 pages. Also, with pre-installed consumables and compatibility with all common operating systems you´re ready to start printing as soon as you set up. And changing cartridges is a quick and simple operation that any user can manage.
  • Very affordable, low running costs
    Two different toner sizes are available for added flexibility and to suit your business needs. The high capacity cartridge gives you one of the lowest costs per page in this market, while the standard size gives you a low price per cartridge. By choosing Epson Return Toner Cartridges you can save even more money and help to protect the environment too.
Printer Type
Personal printer - laser - B/W
6 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 20 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
600 dpi
Parallel, USB
48 MHz
RAM Installed (Max)
2 MB
Media Type
Envelopes, transparencies, labels, plain paper, recycled paper
Total Media Capacity
150 sheets
Monthly Duty Cycle (max)
15000 pages
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Apple MacOS X 10.3.9 - 10.5.x, Microsoft Windows Vista (32/64 bits)
Microsoft Certification
Works with Windows Vista
1-year warranty
38.5 cm x 27.9 cm x 26.1 cm
Printer Type
Personal printer - laser - monochrome
Printer
Print Speed
Wired
Parallel, USB
600 dpi
First Print Out Time B/W
10.2 sec
48 MHz
RAM
RAM Installed (Max)
2 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), F4
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
150 sheets
Media Feeders
1 x automatic - 150 sheets
Max Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Duty Cycle
15000 pages
1 x parallel - 36 PIN Centronics , 1 x USB 2.0
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Power supply - internal
Frequency Required
50/60 Hz
Limited warranty - 1 year - carry-in
10 °C
35 °C
15 - 85%
Sound Emission (Operating)
54 dBA
Sound Emission (Quiet Mode)
39 dBA
38.5 cm
27.9 cm
26.1 cm
6 kg
