Multifunctional: The CX37DTN allows medium-to-large workgroups to print in A4 double-sided plus copy and scan in colour and mono.
Productive: It also features an automatic document feeder as standard, while an additional paper tray as standard allows workgroups to save time by quickly and easily increasing paper capacity.
High-performance: Users benefit from a fast print and copy speed of up to 24ppm, as well as a maximum duty cycle of up to 120,000 pages per month, while professional-quality printing is easily achieved with AcuBrite toner technology.
Easy integration: Featuring PCL6 and PS3 emulations, IPv6 and 802.1x support, plus gigabit Ethernet connectivity, the CX37DTN is designed to fit into complex IT environments. Further increase performance by adding optional HDD and memory devices.
Low TCO: Affordable hardware, combined with long-lasting toner supplies that allow users to optimise cost per page, means total cost of ownership is extremely low. It is ENERGY STAR-qualified for reduced power consumption and environmental impact.
Multifunctional
The CX37DTN allows medium-to-large workgroups to print in A4 double-sided plus copy and scan in color and mono. -
Productive
It also features an automatic document feeder as standard, while an additional paper tray as standard allows workgroups to save time by quickly and easily increasing paper capacity. -
High-performance
Users benefit from a fast print and copy speed of up to 24ppm, as well as a maximum duty cycle of up to 120,000 pages per month, while professional-quality printing is easily achieved with AcuBrite toner technology. -
Easy integration
Featuring PCL6 and PS3 emulations, IPv6 and 802.1x support, plus gigabit Ethernet connectivity, the CX37DTN is designed to fit into complex IT environments. Further increase performance by adding optional HDD and memory devices. -
Low TCO
- Epson AcuLaser CX37DTN - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 120000 impressions
- Max Copying Speed
- Up to 20 ppm (mono) / up to 20 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 24 ppm (mono) / up to 24 ppm (colour)
- Max Printing Resolution
- Scanning
- 600 x 600 dpi
- Original Size
- 215.9 x 500 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- Legal (216 x 356 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 850 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail
- Power
- AC 230 V (50/60Hz)
- 47.2 cm x 55.8 cm x 60.7 cm
- 34.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Copier Type
- Digital
- Laser - colour
- Interface
- Standard Memory
- 256 MB 256 MB
- Max Supported Memory
- 768 MB 768 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c
- First Print Out Time B/W
- 16 sec
- First Print Out Time Colour
- 16 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
Document & Media Handling
- Max Original Size
- 215.9 x 500 mm
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 210 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), F4, 100 x 150 mm, Folio (216 x 330 mm), B6 (125 x 176 mm), 92 x 148 mm
- 850 sheets
- 100 sheets
- 150 sheets
- Input tray - 250 sheets , Bypass tray - 100 sheets , Input tray - 500 sheets , ADF - 35 sheets , Output tray - 150 sheets
- Speed Details
- Printing: up to 24 ppm - B/W , Printing: up to 24 ppm - colour , Copying: up to 20 ppm - B/W , Copying: up to 20 ppm - colour
- 1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
- Network Protocols
- TCP/IP, AppleTalk, IPP, SNMP, HTTP, HTTPS, IPv4, IPv6, FTP, SMTP, DHCP, BOOTP
- LDAP, SSL, TLS, IPsec, 802.1x
- Voltage Required
- 500 Watt
- Power Consumption Standby
- 140 Watt
- Power Consumption Sleep
- 34 Watt
- Warm-Up Time
- 37 sec
- First Copy Out Time B/W
- 11 sec
- First Copy Out Time Colour
- 16 sec
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
- EN 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN55024, EN55022 Class B, IEC 61000-2-2
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site
- 47.2 cm
- 55.8 cm
- 60.7 cm
- 34.7 kg
- Sound Emission
- 33 dBA (idle) / 53.5 dBA (operating)
- 10 °C
- 30 °C
- 15 - 85%
