Epson AcuLaser CX37DN A4 Colour Laser Multifunction Printer
Quicklinx: 8MJBWS00 Mfr#: C11CB82011BY
Multifunctional: The CX37DN allows medium-to-large workgroups to print in A4 double-sided, plus copy and scan in colour and mono.
Productive: It also features an automatic document feeder as standard, while an optional additional paper tray allows workgroups to save time by quickly and easily increasing paper capacity.
High-performance: Users benefit from a fast print and copy speed of up to 24ppm, as well as a maximum duty cycle of up to 120,000 pages per month, while professional-quality printing is easily achieved with AcuBrite toner technology.
Easy integration: Featuring PCL6 and PS3 emulations, IPv6 and 802.1x support, plus gigabit Ethernet connectivity, the CX37DN is designed to fit into complex IT environments. Further increase performance by adding optional HDD and memory devices.
Low TCO: Affordable hardware, combined with long-lasting toner supplies that allow users to optimise cost per page, means total cost of ownership is extremely low. It is ENERGY STAR-qualified for reduced power consumption and environmental impact.
  • Multifunctional
    The CX37DN allows medium-to-large workgroups to print in A4 double-sided, plus copy and scan in color and mono.
  • Productive
  • High-performance
  • Easy integration
  • Low TCO
Epson AcuLaser CX37DN - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
120000 impressions
Max Copying Speed
Up to 20 ppm (mono) / up to 20 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Up to 24 ppm (mono) / up to 24 ppm (colour)
Max Printing Resolution
Scanning
600 x 600 dpi
Original Size
215.9 x 500 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
Legal (216 x 356 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
350 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail
AC 230 V (50/60Hz)
44.7 cm x 55.8 cm x 49 cm
27.7 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Printing Technology
Laser - colour
120000 impressions
Standard Memory
256 MB 256 MB
Max Supported Memory
768 MB 768 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, PCL 5c
Automatic Duplexing
First Print Out Time B/W
16 sec
First Print Out Time Colour
16 sec
Scanning
Optical Resolution
600 x 600 dpi
Document & Media Handling
Max Original Size
215.9 x 500 mm
Original Type
Sheets
35 sheets
Max Media Size
Legal
Min Media Weight
60 g/m²
Max Media Weight
210 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), F4, 100 x 150 mm, Folio (216 x 330 mm), B6 (125 x 176 mm), 92 x 148 mm
350 sheets
Max Media Capacity
850 sheets
100 sheets
150 sheets
Input tray - 250 sheets , Bypass tray - 100 sheets , ADF - 35 sheets , Output tray - 150 sheets
Speed Details
Printing: up to 24 ppm - B/W , Printing: up to 24 ppm - colour , Copying: up to 20 ppm - B/W , Copying: up to 20 ppm - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Network Protocols
TCP/IP, AppleTalk, IPP, HTTP, HTTPS, IPv4, IPv6, FTP, SMTP, DHCP, BOOTP
Security Protocols & Features
LDAP, SSL, TLS, IPsec, 802.1x
AC 230 V (50/60Hz)
500 Watt
Power Consumption Standby
140 Watt
Power Consumption Sleep
34 Watt
Warm-Up Time
37 sec
First Copy Out Time B/W
11 sec
First Copy Out Time Colour
16 sec
Consumables Included
1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
EN 61000-3-2, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN55024, EN55022 Class B, EN 60950-1, EN 60825-1
ENERGY STAR Certified
Limited warranty - 1 year - on-site
44.7 cm
55.8 cm
49 cm
27.7 kg
Sound Emission
33 dBA (idle) / 53.5 dBA (operating)
10 °C
30 °C
15 - 85%
8MJB C2G 2m USB 2.0 A/B Cable - Black In Stock £4.04
