Highly versatile: Consolidate printing, scanning, copying and faxing with a single device that has been designed to fit seamlessly into complex IT environments. Comes network-ready with numerous interfaces and emulations for easy integration, including Gigabit Ethernet, IPv6, Adobe PostScript 3 and PCL 5c/6.
High-quality results at speed: Increase the productivity of your business by printing and copying at high speeds of up to 23 pages per minute in both mono and colour, while ensuring your text and graphics documents are crisp and vibrant with a print resolution of up to 600 x 600dpi.
Tailor to your needs: Make your printer even more productive with an additional 250-sheet paper tray to increase capacity to 500 sheets. A high standard memory of 256MB can be increased by an additional 512MB to further boost performance.
Economical printing: The AcuLaser CX29DNF offers great value for money and its ENERGY STAR-qualified reduced power consumption helps businesses to further reduce total cost of ownership and environmental impact. Automatic double-sided printing as standard can help you save paper usage and costs by up to 50 percent.
Highly versatile
Consolidate printing, scanning, copying and faxing with a single device that has been designed to fit seamlessly into complex IT environments. Comes network-ready with numerous interfaces and emulations for easy integration, including Gigabit Ethernet, IPv6, Adobe PostScript 3 and PCL 5c/6. -
Increase the productivity of your business by printing and copying at high speeds of up to 23 pages per minute in both mono and color, while ensuring your text and graphics documents are crisp and vibrant with a print resolution of up to 600 x 600dpi. -
Make your printer even more productive with an additional 250-sheet paper tray to increase capacity to 500 sheets. A high standard memory of 256MB can be increased by an additional 512MB to further boost performance. -
Economical printing
- Epson AcuLaser CX29DNF - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 40000 impressions
- Max Copying Speed
- Up to 16 ppm (mono) / up to 8 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 23 ppm (mono) / up to 23 ppm (colour)
- Max Printing Resolution
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG
- Fax Resolutions
- 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
- Scanning
- 1200 x 1200 dpi
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- Media Type
- Envelopes, plain paper, labels
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 500 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail
- Power
- AC 230 V (50/60Hz)
- 43 cm x 54.4 cm x 58.4 cm
- 29.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Fax Type
- Plain paper
- Laser - colour
- 40000 impressions
- Display
- 4 lines
- Interface
- Standard Memory
- 256 MB 256 MB
- Max Supported Memory
- 768 MB 768 MB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Printer Drivers / Emulations
- PCL 5e, PCL 6, PostScript 3, PCL 5c
- First Print Out Time B/W
- 15.5 sec
- First Print Out Time Colour
- 15.5 sec
Scanning
- Optical Resolution
- 1200 x 1200 dpi
- Interpolated Resolution
- 9600 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JBIG
- Fax Resolutions
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- One-Touch Dialing
- 8 station(s)
- Speed Dialing
- 200 station(s)
- Automatic redialing, group dialling
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 216 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm)
- 250 sheets
- 500 sheets
- 150 sheets
- Input tray - 250 sheets , Bypass tray - 1 sheet , ADF - 35 sheets
- Speed Details
- Copying: up to 16 ppm (A4) - B/W , Copying: up to 8 ppm (A4) - colour , Printing: up to 23 ppm (A4) - B/W , Printing: up to 23 ppm (A4) - colour , Scanning: up to 16 spm - B/W , Scanning: up to 8 spm - colour
- 1 x USB , 1 x USB host , 1 x Gigabit LAN
- Network Protocols
- TCP/IP, IPP, LPR/LPD, RAW IP (Port 9100), SNMP, HTTP, HTTPS, IPv4, IPv6, Bonjour, FTP, SMTP, DHCP, BOOTP, RARP
- Operating System Support
- MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), Apple Mac OS X 10.4.11 or later, MS Windows Server 2008, MS Windows Server 2008 R2
- Voltage Required
- 410 Wh
- Power Consumption Standby
- 60 Watt
- Power Consumption Sleep
- 35 Watt
- First Copy Out Time B/W
- 21 sec
- First Copy Out Time Colour
- 30 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages
- EN 61000-3-2, EN55022, EN 61000-3-3, EN 61000-4-4, EN 61000-4-3, EN 61000-4-6, EN 61000-4-5, EN 61000-4-11, EN 61000-4-8, EN 60950-1
- ENERGY STAR Certified
- Limited warranty - 1 year - on-site
- 43 cm
- 54.4 cm
- 58.4 cm
- 29.8 kg
- Sound Emission
- 28 dBA (idle) / 53 dBA (operating)
- 10 °C
- 32 °C
- 15 - 80%
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.08 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £19.26 |
