New technology - It offers Epson’s new Advanced Amplitude Modulation (AAM) screen technology to analyse dot placement and produce sharp images with well-defined edges.
High quality output - Epson's resolution improvement technology, AcuLaser Colour-RITech, eliminates uneven edges in text and delivers charts, graphics and even CAD schematics with clear, crisp tones.
Low TCO - It boasts Epson’s lowest cost-per-page for a laser in both mono and colour. This, in addition to its duplex capability which helps save up to 50% on paper usage, plus the ENERGY STAR-qualified reduced power consumption, mean that its TCO is very low.
Engineered for business - It has a compact footprint and the ability to print at up to A3 size in colour. Its print speed of up to 30ppm in A4 mono and colour helps boost productivity and a paper capacity of up to 2055 sheets saves on time refilling it. And the Gigabit Ethernet and PDL support with IPSec, IPv6 and SSL makes integration into complex IT environments hassle-free. It also offers automatic double-sided printing and two additional paper trays as standard.
High durability - It has a duty cycle of up to 100,000 pages, so businesses can be confident that their investment in the Epson range is a sound one.
Large capacity A3 colour
This top-of-the-range A3 colour laser printer offers one of the highest print qualities in its class and a low TCO.
- Epson AcuLaser C9300D2TN - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 62.4 kg
- Media Size Class
- A3/Ledger
- Max Media Size
- A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm)
- Min Media Size (Custom)
- 75 mm x 98 mm
- Max Media Size (Custom)
- 297 mm x 431.8 mm
- Print Speed
- Up to 30 ppm - B/W - A4 (210 x 297 mm) , Up to 30 ppm - colour - A4 (210 x 297 mm) , Up to 21 ppm - B/W duplex - A4 (210 x 297 mm) , Up to 21 ppm - colour duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 dpi
- Image Enhancement Technology
- 4800RIT (Colour Resolution Improvement Technology)
- Automatic Duplexing
- Interface
- USB, Gigabit LAN
- Processor
- 400 MHz
- RAM Installed (Max)
- 256 MB (1 GB) - DDR2 SDRAM
- Language Simulation
- PCL 5C, PostScript 3, EPSON ESC/P 2, EPSON FX, PCL 6, EPSON ESC/P, PDF 1.6
- Media Type
- Envelopes, plain paper
- Total Media Capacity
- 1505 sheets
- Media Handling
- 250-sheet input tray, 2x 550-sheet input trays, 155-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 100000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - internal
- Power
- AC 230V
- System Requirements
- Microsoft Windows Server 2008 R2, Apple MacOS X 10.4.11 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- 1-year warranty
- 50 cm x 53.8 cm x 69.8 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB, Gigabit LAN
- 1200 dpi
- First Print Out Time B/W
- 8.3 sec
- First Print Out Time Colour
- 9.9 sec
- Media Handling
- Processor
- 400 MHz
RAM
- 256 MB / 1 GB (max)
- Technology / Form Factor
- DDR2 SDRAM
Media Handling
- Media Type
- Media Size Class
- A3/Ledger
- Max Media Size
- 75 mm x 98 mm
- 297 mm x 431.8 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), F4
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm)
- Max Printing Width
- 293 mm
- Max Printing Length
- 425.8 mm
- Media Weight
- 60 g/m² - 216 g/m²
- 1505 sheets
- Media Feeders
- 1 x automatic - 155 sheets , 1 x automatic - 250 sheets , 2 x automatic - 550 sheets
- Max Media Capacity
- 2055 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 100000 pages
- Networking
- Print server - internal
- Data Link Protocol
- TCP/IP, AppleTalk, LPR/LPD, FTP, BOOTP, DHCP, DDNS
- Remote Management Protocol
- SNMP, IPP, HTTP
- IPsec
- Expansion Slots
- Memory
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) , 1 x toner cartridge (cyan) , 1 x toner cartridge (magenta) , 1 x toner cartridge (yellow)
- EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 458 Watt
- Power Consumption Stand by / Sleep
- 56 Watt
- Software Included
- Drivers & Utilities, EPSON Web-to-Page, EpsonNet Print, EpsonNet Config, EPSON Status Monitor
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 5 °C
- 32 °C
- 15 - 85%
- Sound Emission (Idle)
- 25 dBA
- Sound Emission (Operating)
- 53 dBA
- 50 cm
- 53.8 cm
- 69.8 cm
- 62.4 kg
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.11 |
