Epson AcuLaser C4200DN Colour Laser Printer
Quicklinx: 7DKQWS00 Mfr#: C11C600001BY
The Epson AcuLaser C4200Series provides demanding workgroups with fast, professional results in both colour and mono. And with economical running costs, you can add vibrant colour to your documents, whenever you want.
Epson AcuLaser C4200DN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
34.5 kg
Media Size Class
A4
Max Media Size
ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
Max Media Size (Custom)
220 mm x 356 mm
Print Speed
Up to 25 ppm - colour - A4 (210 x 297 mm) , Up to 35 ppm - B/W - A4 (210 x 297 mm)
Image Enhancement Technology
EPSON AcuLaser Color 4800 RIT
Automatic Duplexing
Parallel, USB, LAN
PowerPC 600 MHz
RAM Installed (Max)
128 MB (640 MB)
Language Simulation
EPSON ESC/P 2, EPSON FX, PCL 6, IBM 2391, IBM 2390
Total Media Capacity
700 sheets
Monthly Duty Cycle (max)
90000 pages
Print server - Ethernet, Fast Ethernet
Apple MacOS X 10.1.2 or later, Microsoft Windows Server 2003, Microsoft Windows 98/ME/2000/XP
Microsoft Certification
Works with Windows Vista
1-year warranty
43.7 cm x 58.8 cm x 45.7 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
Parallel, USB, LAN
Automatic Duplexing
Language Simulation
Fonts Included
119 x scalable , 14 x bitmapped , 8 x barcode
PowerPC 600 MHz
RAM
RAM Installed (Max)
128 MB / 640 MB (max)
Media Handling
Media Size Class
A4
Max Media Size
220 mm x 356 mm
Media Weight
60 g/m² - 216 g/m²
700 sheets
Media Feeders
1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , 1 x automatic - 550 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 80 g/m²
Max Media Capacity
2350 sheets
Duty Cycle
90000 pages
Print server
Network / Transport Protocol
TCP/IP, AppleTalk, NetBEUI/NetBIOS
Remote Management Protocol
SNMP, Telnet, HTTP
Expansion Slots
Memory , 1 x Epson Type B
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin mini-USB Type B , 1 x parallel
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
EN 60950, EN 61000-3-2, NORDIC, IEC 825-1/EN 60825-1 class 1, IEC 60950, EN 61000-3-3, EN55022 Class B
Power supply - internal
Frequency Required
50/60 Hz
960 Watt
Limited warranty - 1 year
10 °C
32 °C
15 - 85%
43.7 cm
58.8 cm
45.7 cm
34.5 kg
