High-quality results at speed: Increase the productivity of your business by printing at high speeds of up to 23 pages per minute in both mono and colour, while ensuring your text and graphics documents are crisp and vibrant with a print resolution of up to 600 x 600dpi.
Effortless integration: Designed to fit seamlessly into complex IT environments, the AcuLaser C2900N comes network-ready with numerous interfaces and emulations for easy integration, including Gigabit Ethernet, IPv6, Adobe PostScript 3 and PCL 5c/6.
Customise your printer: You can choose from a variety of options to fit your business needs. Make your printer even more productive with an additional 250-sheet paper tray to increase capacity to 500 sheets, while optional double-sided printing can cut paper use and costs by up to 50 percent. A high standard memory of 256MB can be increased by an additional 512MB to further boost performance.
Economical printing: The AcuLaser C2900N offers great value for money and its ENERGY STAR-qualified reduced power consumption helps businesses to further cut total cost of ownership and environmental impact.
Increase the productivity of your business by printing at high speeds of up to 23 pages per minute in both mono and color, while ensuring your text and graphics documents are crisp and vibrant with a print resolution of up to 600 x 600dpi. -
Designed to fit seamlessly into complex IT environments, the AcuLaser C2900N comes network-ready with numerous interfaces and emulations for easy integration, including Gigabit Ethernet, IPv6, Adobe PostScript 3 and PCL 5c/6. -
You can choose from a variety of options to fit your business needs. Make your printer even more productive with an additional 250-sheet paper tray to increase capacity to 500 sheets, while optional double-sided printing can cut paper use and costs by up to 50 percent. A high standard memory of 256MB can be increased by an additional 512MB to further boost performance. -
Economical printing
- Epson AcuLaser C2900N - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 18.4 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 220 mm x 355.6 mm
- Print Speed
- Up to 23 ppm - B/W , Up to 23 ppm - colour
- Max Resolution (B&W)
- 600 dpi
- Max Resolution (Colour)
- 600 dpi
- Interface
- USB, Gigabit LAN
- Processor
- 400 MHz
- RAM Installed (Max)
- 256 MB (768 MB)
- Language Simulation
- PCL 5C, PostScript 3, PCL 6
- Media Type
- Envelopes, plain paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 40000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet - integrated
- Printer Features
- Optional duplex
- System Requirements
- Apple MacOS X 10.4.11 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- 1-year warranty
- 40.4 cm x 46.9 cm x 41.6 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB, Gigabit LAN
- 600 dpi
- 600 dpi
- First Print Out Time B/W
- 15.5 sec
- First Print Out Time Colour
- 15.5 sec
- Fonts Included
- 81 x scalable PCL , 136 x PostScript
- Printer Features
- Optional duplex
- Media Handling
- Processor
- 400 MHz
RAM
- 256 MB / 768 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 220 mm x 355.6 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 216 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) , 1 x manual - 1 sheet - 220 x 355.6 mm weight: 60 g/m² - 216 g/m²
- Max Media Capacity
- 500 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 40000 pages
- Networking
- Print server - integrated
- Data Link Protocol
- TCP/IP, LPR/LPD, SMTP, BOOTP, DHCP, RARP, Bonjour, DDNS
- Remote Management Protocol
- SNMP 1, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS
- Expansion Slots
- Memory
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19798/24712 , 1 x toner cartridge (cyan) - up to 1000 pages ISO/IEC 19798/24712 , 1 x toner cartridge (magenta) - up to 1000 pages ISO/IEC 19798/24712 , 1 x toner cartridge (yellow) - up to 1000 pages ISO/IEC 19798/24712
- EN 61000-3-2, EN55022, IEC 61000-4-11, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN 61000-3-3, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 365 Watt
- Power Consumption Stand by / Sleep
- 60 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 10 °C
- 32 °C
- 10 - 85%
- Sound Emission (Idle)
- 28 dBA
- Sound Emission (Operating)
- 53 dBA
- 40.4 cm
- 46.9 cm
- 41.6 cm
- 18.4 kg
Ink (1)
Epson Toner Cartridge 1 x Black 3000 Pages AcuLaser | In Stock | £88.94 |
Other bundles (1)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
