Space saving: Epson's most compact A4 colour laser-class model only takes up the space of a desktop printer to maximise valuable office workspace, yet can be shared by multiple users across a network via Wi-Fi and Ethernet.
Fast, professional printing: Fast print speeds of up to 15 mono or 12 colour pages a minute combine with a professional-standard print resolution of up to 600 x 600dpi to provide high-quality documents quickly and efficiently. Performance is enhanced with a large standard memory of 128MB.
Economical to run: Very little maintenance is required and the toner cartridge is the only supply item which needs to be replaced. Together with ENERGY STAR-qualified reduced power consumption, the total cost of ownership and environmental impact are kept to a minimum.
Space saving
Epson's most compact A4 color laser-class model only takes up the space of a desktop printer to maximise valuable office workspace, yet can be shared by multiple users across a network via Wi-Fi and Ethernet. -
Fast print speeds of up to 15 mono or 12 color pages a minute combine with a professional-standard print resolution of up to 600 x 600dpi to provide high-quality documents quickly and efficiently. Performance is enhanced with a large standard memory of 128MB. -
Economical to run
- Epson AcuLaser C1750W - printer - colour - LED
- Printer Type
- Workgroup printer - LED - colour
- 10.6 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 15 ppm - B/W , Up to 12 ppm - colour
- Max Resolution (B&W)
- 600 dpi
- Max Resolution (Colour)
- 600 dpi
- Interface
- USB, LAN, Wi-Fi(n)
- Processor
- 384 MHz
- RAM Installed (Max)
- 128 MB
- Language Simulation
- Windows GDI driver
- Media Type
- Envelopes, plain paper
- Total Media Capacity
- 160 sheets
- Monthly Duty Cycle (max)
- 20000 pages
- Networking
- Print server - Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n - integrated
- System Requirements
- Apple MacOS X 10.4.11 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 39.4 cm x 30.4 cm x 23.4 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- 600 dpi
- 600 dpi
- First Print Out Time B/W
- 12.5 sec
- First Print Out Time Colour
- 15 sec
- Processor
- 384 MHz
RAM
- 128 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 160 sheets
- Media Feeders
- 1 x automatic - 160 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 20000 pages
- Networking
- Print server - integrated
- Data Link Protocol
- TCP/IP, LPR/LPD, SMTP, BOOTP, DHCP, DNS, POP3, RARP, Bonjour
- Remote Management Protocol
- SNMP 1, SNMP 2, HTTP
- WEP, WPA-PSK, WPA2-PSK
- Connections
- 1 x USB , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 700 pages ISO/IEC 19798/24712 , 1 x toner cartridge (cyan) - up to 700 pages ISO/IEC 19798/24712 , 1 x toner cartridge (magenta) - up to 700 pages ISO/IEC 19798/24712 , 1 x toner cartridge (yellow) - up to 700 pages ISO/IEC 19798/24712
- EN55022, IEC 61000-3-2, IEC 61000-3-3, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, IEC 60950, EN 60950-1, IEC 60825-1, EN 60825-1
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 340 Watt
- Power Consumption Stand by / Sleep
- 69 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - on-site
- 10 °C
- 32 °C
- 10 - 85%
- Sound Emission (Idle)
- 21 dBA
- Sound Emission (Operating)
- 49 dBA
- 39.4 cm
- 30.4 cm
- 23.4 cm
- 10.6 kg
