Epson 5000 ANSI Lumens WUXGA 3LCD Technology Meeting Room 4.8Kg
Quicklinx: D9LKWS00 Mfr#: V11H871041
Type: LCD projector
Brightness: 5000ANSI lumens
Contrast Ratio: 4001 /150001
Portability: Non-portable
Resolution: 1920 x 1200
More than 50 In Stock
£857.44 ex VAT
£1,028.92 inc VAT
Offering excellent brightness to deliver perfect presentations with Gesture Presenter and intuitive, easy-to-use features. Our super-bright new business projector offers an outstanding brightness 5,000 lumens and full HD resolution. The EB-2250U is designed to project a scalable image size of up to a 300 inches, and offers connectivity options such as dual HDMI and optional Wi-Fi. Outstanding quality display of up to 300 inches Full HD resolution combined with Epson’s 3LCD technology ensures high-quality content has more vivid colours and brighter images. HDMI connectivity guarantees sharper and clearer presentations delivered on a scalable image size of up to 300 inches.
  • Outstanding quality display
    Full HD resolution combined with Epson's 3LCD technology ensures high-quality content has more vivid colors and brighter images. HDMI connectivity guarantees sharper and clearer presentations delivered on a scalable image.
  • Simple connectivity
    The EB-2250U offers a wide range of connectivity options, including screen mirroring, LAN and HDMI input.
  • Keep costs down
    Project for longer with improved reliability and a longer lamp life in Eco mode.
  • Home screen
    The home screen offers quick and easy access to a variety of useful functions, such as connection sources. Wireless connections can also be made easily using the information on screen.
  • Gesture presenter
    Change slides by simply moving your hand, making even smarter presentations a reality by liberating the user from their remote control or mouse.
  • Value-added flexibility
    The Multi-PC projection software bundled with the EB-2250U makes it possible to connect up to 50 computers and partition the screen for split screen projection capability - offering far better cost-effectiveness and flexibility than a flat-panel display.
Epson EB-2250U - LCD projector - LAN - white
LCD projector - 1080p
White
Brightness (White)
5000 lumens
Brightness (Colour)
5000 lumens
Contrast Ratio
400:1 / 15000:1 (dynamic)
Resolution
WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
1.07 billion colours
Bulb type
300 Watt
Bulb life cycle
Up to 5000 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, composite video LAN
Speakers
Speaker(s) - integrated
AC 230V (50 - 60 Hz)
420 Watt
37.7 cm x 29.1 cm x 11 cm
4.8 kg
3-year warranty
Ethernet
Enclosure Colour
White
Projector
Brightness (White)
5000 lumens
Brightness (Colour)
5000 lumens
Brightness (Reduced)
3800 lumens
Contrast Ratio
Image Size
127 cm - 762 cm
Projection Distance
1.5 m - 9 m
Throw Ratio
1.38 - 2.28:1
Digital Zoom Factor
1.6x
Resolution
WUXGA - WUXGA (1920 x 1200)
Native Aspect Ratio
16:10
Colour Support
Bulb type
300 Watt
Bulb life cycle
sRGB colour profile, Blackboard Mode, Auto Vertical Keystone, Split Screen, DICOM Simulation Mode, Direct Power On, Direct Power Off, Dynamic Mode, instant on/off
Lens
Focus Type
Manual
Lens Aperture
F/1.5-2.0
Keystone Correction Direction
Horizontal, vertical
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, DisplayPort, composite video, MHL
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
16 Watt
Speakers
1 x mixed channel
1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 1 x serial RS-232C , 1 x network - RJ-45 , 1 x VGA input / output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort - 20 pin DisplayPort , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x HDMI - 19 pin HDMI Type A , 1 x Mobile High-Definition Link (MHL) / HDMI
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
Power Source
AC
420 Watt
Power Consumption Stand by
0.5 Watt
Software Included
EasyMP Network Projection, EasyMP Slide Converter, EasyMP Monitor, EasyMP Multi PC Projection
37.7 cm
29.1 cm
11 cm
4.8 kg
Limited warranty - 3 years / 8000 hours - on-site , Limited warranty - lamp - 1 year / 1000 hours
5 °C
20 - 80%
Sound Emission
39 dBA
29 dBA
D9LK Epson ELPMB23 Projector Mount In Stock £109.44
D9LK Epson Wireless Adaptor LAN B/G/N In Stock £104.30
Type: LCD projector
Brand: Epson
Price Range Ex VAT: £750 - £1000
