This is the Mi, Home heating bundle, consisting of radiator valves and gateway. Each eTRV controls a radiator valve to regulate the heating in the room, based on timed programs, set temperatures. Using the eTRV improves your comfort and saves energy. The benefit of having eTRVs is that it enables you to control each radiator or room individually, rather than heating your whole house from a single thermostat. Therefore you only heat the bedroom, when it is in use, which is likely to be at a different time to the lounge or sitting room. By only heating the rooms you are in you can make significant savings. The radiator valves can be used with other features, such as programs. This means, you are able to set the required radiator valve to a specific temperature and at specific time on your settings in the app.
- Energenie Mi|Home Heating Pack - home automation kit
- Product Type
- Home automation kit
- Functions
- Control heating systems
- Internet of Things (IoT) Platform
- Hue, OpenThings
- Package Content
- Gateway, radiator thermostat
- Connectivity
- Wireless
- Frequency Band
- 434.3 MHz
- Product Type
- Functions
- Package Content
- Components
- 3 x radiator thermostat , Gateway
- Connectivity Technology
- Wireless
- Max Range Open Space
- 25 m
- Frequency Band
- 434.3 MHz
- LED indicator
- Internet of Things (IoT) Compatible
- Platform
- Hue, OpenThings
- Communications Type
- Product-to-product
- Compatible Services
- IFTTT
- IP20
- Dimensions & Weight Details
- Radiator thermostat: 4.5 cm x 4.5 cm x 11 cm
