The MiHome Double Wall Socket is a radio controlled unit with individual power switching for each socket. Switching is initiated either by radio control signal or manually by pressing the button on the housing.
- Energenie Mi|Home Double Wall Socket - socket switch - white
- Product Type
- Socket switch
- Environment
- Indoor
- Functions
- Turn power on/off
- Connectivity
- Wireless
- Frequency Band
- 433.92 MHz
- White
- Localisation
- United Kingdom
- 1-year warranty
- 14.5 cm x 3.3 cm x 8.5 cm
- Product Type
- Socket switch
- Environment
- Indoor
- Functions
- Turn power on/off
- Connectivity Technology
- Wireless
- Max Range Indoors
- 25 m
- Frequency Band
- 433.92 MHz
- In-wall mountable, on / off button, LED indicator, up to 3000 Watt (each socket) OOK modulation
- Product Material
- Plastic
- White
- Localisation
- United Kingdom
- Nominal Voltage
- AC 230V
- Warranty
- 1-year warranty
- BS 5733, IP20, DIN EN 61058-1, EN 301 489-1, EN 62479, RTTE
- 14.5 cm
- 3.3 cm
- 8.5 cm
- 210 g
- -5 °C
- 40 °C
