Extra juice right when you need it! The Power Clip is a back-up battery for your smartphone when it runs out of power.
- EMTEC Power Clip U400 - external battery pack Li-Ion
- Product Type
- External battery pack
- 3.3 cm x 2.2 cm x 7.2 cm
- 65 g
- Output Connector Type
- Lightning
- Voltage Provided
- 5 V
- Battery
- Lithium Ion 2600 mAh
- Cables
- Micro-USB cable
- Designed For
- Apple iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus; iPod nano (7G); iPod touch (5G, 6G)
- Product Type
- 3.3 cm
- 2.2 cm
- 7.2 cm
- 65 g
- Voltage Provided
- 5 V
- Output connectors
- Apple Lightning
- Max Electric Current
- 1 A
- Technology
- Lithium Ion
- Capacity
- 2600 mAh
- Run Time (Up To)
- 11 hours
- Recharge Time
- 4.5 hour(s)
- Max Recharge Cycles
- 300
- Battery level indicator
- Cables Included
- Micro-USB cable
- MFI
- Designed For
- Apple iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus , Apple iPod nano (7G) , Apple iPod touch (5G, 6G)
