Elo 1715L 17" 1280x1024 25ms VGA LCD Monitor
Quicklinx: 82KTWS00 Mfr#: E719160
Diagonal Size: 17in
Max Resolution: 1280 x 1024
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15)
£566.59 ex VAT
£679.90 inc VAT
The 1715L touchmonitor is designed, developed and built to provide the most cost-effective touch solutions for system integrators and VARs. It packs Elo quality and reliability into an integrated, affordable touchmonitor. The 3-track magnetic stripe reader (MSR), programmable to either HID or Keyboard Emulation (USB only), is easily installed by the user, providing an elegant, integrated solution and eliminating the need for external brackets or attachments. IntelliTouch surface acoustic wave pure-glass touchscreen technology provides superior image quality and can be activated with finger or glove.
Elo Desktop Touchmonitors 1715L IntelliTouch - LED monitor - 17"
LED-backlit LCD monitor - 17" - touchscreen
Touch-screen
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 75 Hz
Brightness
225 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Voltage
Dark grey
39.1 cm x 20.3 cm x 36.6 cm
6.9 kg
UL, TUV GS, VCCI, C-Tick, cUL, IC, FCC, RoHS
Display Type
Diagonal Size
17"
Aspect Ratio
5:4
Native Resolution
Brightness
225 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
80 kHz
Horizontal Viewing Angle
+85 / -85
Vertical Viewing Angle
+80 / -80
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, contrast, H/V position, colour temperature, phase, clock
OSD Languages
English, German, French, Spanish, Japanese
IntelliTouch Surface Wave, Sync on Green
Dark grey
6.9 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Surface acoustic wave
VGA , 2 x serial , USB
Mechanical
VESA Mounting Interface
100 x 100 mm
Wall mountable
1 x VGA cable , 1 x serial cable , 1 x USB cable
Backlight Life
30,000 hours
MTBF
50,000 hour(s)
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
21 Watt
20 - 80%
Diagonal Size: 17in
Response Time: 5ms
Speakers: None
Brand: ELO
Price Range Ex VAT: £500 - £750
