Elo 1515L 15" 1024x768 14.5ms VGA LCD Monitor -  Dark Grey
Quicklinx: 8DNXWS00 Mfr#: E344320
The Elo Touch Solutions 1515L touchmonitor is designed, developed and built to provide a cost-effective touch solution for system integrators and VARs. It packs Elo quality and reliability into a integrated, affordable touchmonitor with a footprint smaller than a standard 15" display. This cost and space-saving touchmonitor is "designed for touch"- the technology is built into the 1515L from the ground up and not added as an afterthought by altering the original monitor. It includes a stable base, with controls that are placed on the side rather than the front and are locked-out for public use. The 1515L can function as a desktop or wall-mounted unit and includes a VESA mounting option. AccuTouch five-wire resistive touchscreen technology is the preferred solution for applications that demand reliability, input flexibility and contamination resistance.
Elo Desktop Touchmonitors 1515L AccuTouch - LCD monitor - 15"
LCD monitor - 15" - touchscreen
Touch-screen
Aspect Ratio
4:3
Native Resolution
1024 x 768 at 75 Hz
Brightness
200 cd/m²
Contrast Ratio
500:1
Response Time
11.7 ms
Colour Support
16.7 million colours
Input Connectors
VGA
Screen Coating
Anti-glare
Voltage
Dark grey
35 cm x 17.5 cm x 31 cm
4.8 kg
UL, VCCI, C-Tick, cUL, MPR III, SEMKO, IC, FCC, RoHS
Display Type
LCD monitor / TFT active matrix
Diagonal Size
15"
Aspect Ratio
4:3
Native Resolution
1024 x 768 at 75 Hz
Brightness
200 cd/m²
Contrast Ratio
500:1
Colour Support
Response Time
11.7 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
60.2 kHz
Horizontal Viewing Angle
+65 / -65
Vertical Viewing Angle
+55 / -65
Screen Coating
Anti-glare
Controls & Adjustments
Brightness, contrast, H/V position, colour temperature, phase, clock
OSD Languages
English, German, French, Spanish, Japanese
AccuTouch Five-Wire Resistive, Sync on Green
Dark grey
4.8 kg
Input
Touch-screen - touchscreen
Movement Detection Technology
Resistive
1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
Mechanical
VESA Mounting Interface
75 x 75 mm
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable , 1 x USB cable , 1 x serial cable
Backlight Life
30,000 hours
MTBF
50,000 hour(s)
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
30 Watt
20 - 80%
