The Elite VMAX2 Series is an enhanced multi-purpose electric/motorized screen. It features Internal Infrared (IR) and Radio Frequency (RF) Receivers providing total control while maintaining the streamlined simplicity of this product. For added durability and enhanced product appearance, the Elite VMAX2 Series uses an all-steel casing construction including the end caps.
The VMAX2 Series comes with 2-30 inches of Top Black masking borders along with side and bottom masking to enhance the format of your presentation to avoid projection overshoot. The VMAX2 Series has pre-set but adjustable vertical limit switches for versatility in your drop/rise settings.
- Elite Screens VMAX2 Series VMAX150XWV2 - projection screen - 150" (381 cm)
- Product Type
- Projection screen - motorised
- Placing / Mounting
- Ceiling mountable, wall mountable
- Package Content
- 3-way wall switch receiver, IR remote control
- White
- Projection Screen Image Diagonal Size
- 150" (381 cm)
- Projection Image Size
- 305 cm x 229 cm
- Aspect Ratio
- 4:3
- Screen Surface
- MaxWhite
- Length
- 338 cm
- 15.5 kg
- 2-year warranty
- Product Type
- Package Content
- Image Diagonal Size
- 150" (381 cm)
- Image Width
- 305 cm
- Image Height
- 229 cm
- Screen Surface
- MaxWhite
- Aspect Ratio
- 4:3
- Gain
- 1.1x
- Viewing Angle
- 160°
- Mildew-resistant, fire resistant, washable, Low Voltage Control
- Length
- 338 cm
- 15.5 kg
- White
- Mounting Kit
- Included
- Remote control
- Limited warranty - replacement - 2 years
