Elite Screens VMAX2 Projector Screen, W130.7" D150" (16:9), White casing
Quicklinx: C08QWS00 Mfr#: VMAX150XWH2
The Elite VMAX2 Series is an enhanced multi-purpose electric/motorized screen. It features Internal Infrared (IR) and Radio Frequency (RF) Receivers providing total control while maintaining the streamlined simplicity of this product. For added durability and enhanced product appearance, the Elite VMAX2 Series uses an all-steel casing construction including the end caps.
The VMAX2 Series comes with 2-30 inches of Top Black masking borders along with side and bottom masking to enhance the format of your presentation to avoid projection overshoot. The VMAX2 Series has pre-set but adjustable vertical limit switches for versatility in your drop/rise settings.
Elite Screens VMAX2 Series VMAX150XWH2 - projection screen - 150" (381 cm)
Projection screen - motorised
Placing / Mounting
Ceiling mountable, wall mountable
Package Content
IR remote control, wall control switch
White
Projection Screen Image Diagonal Size
150" (381 cm)
Projection Image Size
332 cm x 187 cm
Aspect Ratio
16:9
Screen Surface
MaxWhite
16.2 kg
Placing / Mounting
Package Content
Image Diagonal Size
150" (381 cm)
Image Width
332 cm
Image Height
187 cm
Screen Surface
MaxWhite
Aspect Ratio
16:9
Gain
1.1x
Viewing Angle
160°
Extra Border Size
10.2 cm (top)
Mildew-resistant, washable, black backing, black borders
16.2 kg
White
Trigger
Limited warranty - parts and labour - 2 years
