The EZ-Cinema screen is designed to be used as an easy to operate portable screen for a variety of presentation environments. Its design enables it to be versatile for use in either classroom, conference room, home or patio presentations.
Versatile usability
The Elite ez-Cinema is designed to accommodate various viewing scenarios, from movie nights in your backyard to presentations in conference rooms. This flexibility makes it a valuable addition to any entertainment setup. -
Efficient setup process
With its straightforward assembly, organizing a viewing event is hassle-free. The screen can be quickly set up or taken down, allowing users to focus on enjoying their time without any complicated installation.
- Elite ez-Cinema F100NWH - projection screen - 100" (254 cm)
- Product Type
- Projection screen
- Projection Screen Image Diagonal Size
- 100" (254 cm)
- Projection Image Size
- 221 cm x 125 cm
- Aspect Ratio
- 16:9
- Screen Surface
- Matte White
- 1-year warranty
- Product Type
- Projection screen
- Image Diagonal Size
- 100" (254 cm)
- Image Width
- 221 cm
- Image Height
- 125 cm
- Screen Surface
- Matte White
- Aspect Ratio
- 16:9
- Washable
- Limited warranty - parts and labour - 1 year
