The EZ-Cinema screen is designed to be used as an easy to operate portable screen for a variety of presentation environments. Its design enables it to be versatile for use in either classroom, conference room, home or patio presentations.
- Elite ez-Cinema F100NWH - projection screen - 100" (254 cm)
- Product Type
- Projection screen
- Projection Screen Image Diagonal Size
- 100" (254 cm)
- Projection Image Size
- 221 cm x 125 cm
- Aspect Ratio
- 16:9
- Screen Surface
- Matte White
- 1-year warranty
- Product Type
- Projection screen
- Image Diagonal Size
- 100" (254 cm)
- Image Width
- 221 cm
- Image Height
- 125 cm
- Screen Surface
- Matte White
- Aspect Ratio
- 16:9
- Washable
- Limited warranty - parts and labour - 1 year
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HKPX 048566 Condition: Customer return - item has been opened but is in excellent condition |
£50.06 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
