Elgato HD60 PVR Next Gen Gameplay Recording
Quicklinx: B2F2WS00 Mfr#: 1GC109901001
Empower yourself
Renowned for its efficiency, compatibility, and powerful features – countless content creators have dubbed HD60 the go-to device for top-quality capture. Why? Because they’ve experienced what it can do. You should, too.
Powerful recording
With HD60, easily record unlimited footage in flawless 1080p quality at 60 frames per second. Do your creativity justice. Upload content you’re proud of. And build an archive that truly reflects your legacy.
Powerful performance
Capturing in full HD requires lots of horsepower, which is why HD60 features a cutting-edge H.264 encoder dedicated to reducing the load on your processor. Throw in the tried-and-tested reliability of a USB 2.0 interface, and you have a capture device you can count on.
Powerful form
A matte-black exterior and an LED status strip make HD60 a slick yet unassuming match for any setup. Barely bigger than a smartphone, it doesn’t get in your way. And, weighing little more than a deck of cards, it’s ideal for recording on the go.
Powerful creation
Record your gameplay, audio, webcam, and overlays as separate tracks, and access them exactly where you need them. Forget to hit record? Simply slide back in time and capture every moment retroactively. Edit your footage on the fly and easily upload it to your favorite social networks. Or easily export your clips and create masterpieces in the editing suite of your choice.
Power to You
HD60 is a surefire capture solution. Having powered millions of uploads since its inception, this iconic device will have you recording like a boss, time and time again.
  • Be next-gen
    You constantly push the limits, and so should the gaming gear that powers you. With superior H.264 hardware encoding, Elgato Game Capture HD60 raises the bar to a whole new level. Easily capture stunning 1080p with 60 fps, and enjoy incredibly smooth footage in easily manageable files. The next generation of gameplay sharing has finally arrived, and it's the perfect match for your Xbox One or PlayStation 4.
  • Be prepared
    When you're in the zone, you shouldn't have to worry about your capture. With Flashback Recording, Elgato Game Capture HD60 has your back - simply slide back in time on your PC or Mac and hit the record button retroactively. The lag-free passthrough to your TV will let you focus on your game, until you're ready to marvel at your feats. Re-living greatness has never been this easy.
  • Be live
    Nothing beats sharing your journey right when it happens. The built-in Live Streaming feature gets you up and running on Twitch, YouTube or Ustream in a snap, but it doesn't stop there. Now, Stream Command puts you in charge: easily add your webcam and overlays, and change your stream layout on-the-fly with scenes. Add your voice with the built-in Live Commentary feature, and you're all set for the big show.
  • Be in control
    You've achieved epicness, and with Elgato Game Capture HD60, there is no limit to what you'll be able to do next. Seamlessly capture hours of your best moments in unmatched quality and access them directly right where you need them - you'll be instantly ready to create history. You don't even have to choose between live streaming and high quality capture. No matter what resolution you stream, you can simultaneously capture full resolution 1080p, with separate tracks of all of your stream elements. Now, your stream archive is only the beginning.
  • Be you
    Elgato Game Capture HD60 was created with the next generation of gaming in mind. Designed to give you full control without getting in your way, so you can shape its legacy. Now more than ever, the gaming experience is all about sharing. Come be a part of it.
Elgato Game Capture HD 60 - video capture adapter - USB 2.0
Video capture adapter
Interface Type
USB 2.0
11.2 cm x 7.5 cm x 1.9 cm
106 g
Video Input
HDMI
Video Modes
1080i, 1080/30p, 1080/60p, 480p, 576i, 576p, 720/30p, 720/60p
Digital Video Format
H.264
Audio Input Support
Standard
Apple MacOS X 10.9 or later, Microsoft Windows 7 or later
Interface Type
USB 2.0
11.2 cm
7.5 cm
1.9 cm
106 g
Video
Interface Type
HDMI
Video Modes
H.264
Audio Input Support
Standard
1 x audio / video - HDMI input - 19 pin HDMI Type A , 1 x audio / video - HDMI output - 19 pin HDMI Type A
1 x USB 2.0 - mini-USB Type B
1 x HDMI cable - external , 1 x USB cable - external
System Requirements Details
MacOS X 10.9 - Core i5 RAM 4 GB , Windows 7 - Core i5 RAM 4 GB
