Elgato Game Capture HD60 Pro
Quicklinx: BMSXWS00 Mfr#: 1GC109901002
Perfect your content
You seek excellence and strive for precision. With optimum video capture, dedicated encoding, ultra-low latency technology, and more, HD60 Pro is your key to unlocking content of the highest calibre. The gaming experience is all about sharing. Stream and record your Xbox, PlayStation or Nintendo Switch gameplay and share your journey with friends, fans and generations to come.
Perfect recording
Textures, tones, shadows, lens flares – you treasure every detail, so recording in the highest possible quality is non-negotiable. HD60 Pro features an advanced, onboard H.264 encoder that enables you to record unlimited footage in superb 1080p60 quality, at a bit-rate up to 60Mbps. This, all while keeping your project file sizes small and CPU load minimal. Why settle for less?
Perfect streaming
HD60 Pro boasts Instant Gameview, powering your stream with superior low latency technology. The result? An unbeatable broadcasting experience that awards you absolute, real-time satisfaction. You’re live on Twitch or YouTube in a flash, and it’s never felt more natural.
Perfect control
Ever wrapped up a stellar stream, only to wish you could bump up the resolution for a YouTube upload? Now you can. With Master Copy, stream to Twitch and simultaneously record your gameplay in sharp quality up to 1080p60. What’s more? Master Copy saves each element of your stream – like webcam and overlays – as separate tracks, enabling you to edit your videos without compromise.
Perfect creation
With Stream Command, customise your layout without limits. Add your webcam, overlays, alerts and more, and change your stream layout on the fly with scenes.
Forget to hit record? No sweat. Simply slide back in time and record every moment retroactively.
Add your voice with the built-in Live Commentary feature, and you're all set for the big show.
Perfect construction
Your PC sets the bar for high-end design? HD60 Pro is no different. With black electro-galvanised steel casing accentuated by sharp, geometric edges, slick grilles, and prominent port labels, this PCIe card boosts the benchmark for head-turning hardware.
  • Perfect quality
    With HD60 Pro, stunning 1080p capture with 60 fps is only the beginning. Instant Gameview feeds your stream with no delay, while simultaneous H.264 hardware encoding provides you with incredibly smooth footage in easily manageable files. Why would you ever settle for less?
  • Perfect streaming
    Nothing beats sharing your journey right when it happens. The built-in Live Streaming feature gets you up and running on Twitch or YouTube in a snap, but it doesn't stop there. HD60 Pro introduces Instant Gameview, feeding your stream with superior low latency technology. Add your webcam, overlays and more with Stream Command, and change your stream layout on-the-fly with scenes. Add your voice with the built-in Live Commentary feature, and you're all set for the big show.
  • Perfect recording
    HD Pro uses advanced hardware H. 264 encoding to capture your gameplay in stunning 1080p Full HD, while keeping the file size low. With Flashback Recording, simply slide back in time on your PC and hit the record button retroactively. Seamlessly record hours of your best moments in unmatched quality and access them directly right where you need them - you'll be instantly ready to create history.
  • Perfect performance
    Thanks to Master Copy, you don't even have to choose between live streaming and high quality recording. Simultaneously save a full resolution 1080p60 recording, with separate tracks of your webcam and live commentary. Now, your stream archive is only the beginning.
  • Your content, perfected
    No matter what content you create, HD60 Pro has your back. With the most powerful capture card, you can focus on what you do best, without compromises. Take your content to the next level, and share your legacy.
Elgato Game Capture HD 60 Pro - video capture adapter - PCIe
Video capture adapter
Interface Type
PCIe
Video Input
HDMI
Video Modes
1080i, 1080/30p, 1080/60p, 480p, 576i, 576p, 720/30p, 720/60p
Digital Video Format
H.264
Audio Input Support
Standard
Windows 10 64-bit Edition
Interface Type
PCIe
Video
Interface Type
HDMI
Video Modes
H.264
Audio Input Support
Standard
1 x audio / video - HDMI input - 19 pin HDMI Type A , 1 x audio / video - HDMI output - 19 pin HDMI Type A
