Your skills. Immortalised.
The gaming experience is all about sharing. With Elgato Game Capture HD, you can record and stream your Xbox or PlayStation gameplay and share your journey with friends, fans and generations to come.
Be the best.
Game Capture HD uses advanced hardware H.264 encoding to capture your gameplay in stunning 1080p Full HD, while keeping the file size low. At the same time, your console’s picture is passed through to your TV via HDMI, so you can keep on enjoying your game on the big screen – in pristine quality, without delay.
Be efficient.
Game Capture HD doesn’t need a lot of cables or even a power supply to record your game: With direct PlayStation 4, Xbox One, Xbox 360, PlayStation 3 and Wii U input, you can use a single cable to connect it to your console. And since it’s only about the size of a deck of cards, you can be sure it will not intimidate your other gaming gear.
Be prepared.
You never know when a moment worth capturing arises. With Flashback Recording, Elgato Game Capture HD has your back. Flashback Recording lets you time-shift your gameplay, so that you can simply slide back in time on your Mac or PC and hit the record button retroactively. Re-living greatness has never been this easy.
Be heard.
Use any microphone that’s connected to your computer, find the perfect balance with your game audio and even automatically lower the volume of your game whenever you speak. With the Live Commentary feature, all of this is only a click away. Now it’s up to you to think of something brilliant to say.
Be social.
Elgato Game Capture HD, it’s not just about you and the game any more. With one click, you can share your gameplay with your friends and fans on YouTube, Facebook and Twitter. Even better, the tailor-made Elgato Game Capture HD software allows you to quickly trim your gaming scenes and pass them on to your favourite editing software.
- Elgato Game Capture HD - video capture adapter - USB 2.0
- Video capture adapter
- Interface Type
- USB 2.0
- 7.3 cm x 10.9 cm x 2.4 cm
- 142 g
- Video Input
- HDMI
- Digital Video Format
- H.264
- Audio Input Support
- Standard
- OS Required
- Microsoft Windows 7, Apple MacOS X Lion 10.7
- Interface Type
- USB 2.0
- 7.3 cm
- 10.9 cm
- 2.4 cm
- 142 g
Video
- Interface Type
- HDMI
- H.264
- Standard
- 1 x audio / video - HDMI input - 19 pin HDMI Type A , 1 x audio / video - 7 PIN mini-DIN , 1 x audio / video - HDMI output - 19 pin HDMI Type A
- Connections
- 1 x USB 2.0 - mini-USB Type B
- Cables Included
- 1 x A/V cable - external , 1 x HDMI cable - external , 1 x USB cable - external
- OS Required
