Elgato EyeTV Netstream 4Sat Network Tuner for DVB-S2
Quicklinx: B2FBWS00 Mfr#: 1SI108101000
With EyeTV Netstream 4Sat, satellite TV loses its restrictions at last: no longer stuck in a socket wired into the wall, you can now easily record a second channel, watch another program in a different room or enjoy football in the garden. Enjoy HD-quality satellite TV on any screen in your home - whether on a tablet, smartphone, computer or TV receiver.
  • Satellite TV without cables
    Forget about cabling - EyeTV Netstream 4Sat makes satellite TV simply part of your home network. Your devices can receive satellite TV over your existing Wi-Fi network - anywhere in your home and even on your patio or in your garden.
  • Satellite TV the easy way
    Setting up EyeTV Netstream 4Sat is a breeze: connect it up, install the app, enjoy. You can even skip the tedious channel scan with your tablet or smartphone on popular providers such as ASTRA - plus, all of your devices find the TV signal completely automatically.
  • Satellite TV at your fingertips
    Enjoy live TV in no time at all, pause the program you're watching, and record the highlights really easily. You don't need to deal with the technical side of things either: the app even takes care of complex functions such as LNB and DiSEqC control in the background.
  • Satellite TV in HD
    The tablets and smartphones are packed with pixels - even on small screens with Retina or full-HD resolutions, HD channels look really impressive thanks to their much greater picture quality. Thanks to automatic hardware transcoding, EyeTV Netstream 4Sat brings HD channels directly to your tablet or smartphone for the first time - without overloading your home network or mobile device.
Elgato EyeTV Netstream 4Sat - digital TV tuner - USB 2.0, Ethernet 100
Digital TV tuner - DVB-S2
Interface Type
25 cm x 12.6 cm x 4.1 cm
806 g
Included Input Adapter Accessories
Power adapter
Digital Video Format
DVB
Microsoft Windows 7, Apple MacOS X 10.6.8 or later
Interface Type
25 cm
12.6 cm
4.1 cm
806 g
Video
DVB
4 x satellite antenna - input - F connector
2 x USB 2.0 - 4 pin USB Type A , 1 x network - 100Base-TX - RJ-45
Power adapter
1 x network cable - external
Software Included
Drivers & Utilities
System Requirements Details
Windows 7 - 2 GHz - RAM 1 GB
B2FB C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
B2FB C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.84
