With EyeTV Netstream 4Sat, satellite TV loses its restrictions at last: no longer stuck in a socket wired into the wall, you can now easily record a second channel, watch another program in a different room or enjoy football in the garden. Enjoy HD-quality satellite TV on any screen in your home - whether on a tablet, smartphone, computer or TV receiver.
Satellite TV without cables
Forget about cabling - EyeTV Netstream 4Sat makes satellite TV simply part of your home network. Your devices can receive satellite TV over your existing Wi-Fi network - anywhere in your home and even on your patio or in your garden. -
Satellite TV the easy way
Setting up EyeTV Netstream 4Sat is a breeze: connect it up, install the app, enjoy. You can even skip the tedious channel scan with your tablet or smartphone on popular providers such as ASTRA - plus, all of your devices find the TV signal completely automatically. -
Satellite TV at your fingertips
Enjoy live TV in no time at all, pause the program you're watching, and record the highlights really easily. You don't need to deal with the technical side of things either: the app even takes care of complex functions such as LNB and DiSEqC control in the background. -
Satellite TV in HD
The tablets and smartphones are packed with pixels - even on small screens with Retina or full-HD resolutions, HD channels look really impressive thanks to their much greater picture quality. Thanks to automatic hardware transcoding, EyeTV Netstream 4Sat brings HD channels directly to your tablet or smartphone for the first time - without overloading your home network or mobile device.
- Elgato EyeTV Netstream 4Sat - digital TV tuner - USB 2.0, Ethernet 100
- Digital TV tuner - DVB-S2
- Interface Type
- 25 cm x 12.6 cm x 4.1 cm
- 806 g
- Included Input Adapter Accessories
- Power adapter
- Digital Video Format
- DVB
- OS Required
- Microsoft Windows 7, Apple MacOS X 10.6.8 or later
- Interface Type
- 25 cm
- 12.6 cm
- 4.1 cm
- 806 g
Video
- DVB
- 4 x satellite antenna - input - F connector
- Connections
- 2 x USB 2.0 - 4 pin USB Type A , 1 x network - 100Base-TX - RJ-45
- Included Accessories
- Power adapter
- Cables Included
- 1 x network cable - external
- Software Included
- Drivers & Utilities
- OS Required
- System Requirements Details
- Windows 7 - 2 GHz - RAM 1 GB
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.67 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.82 |
