Eve Room
Live smarter by knowing more about the place you care about most. Eve Room senses indoor air quality, temperature, and humidity. Learn how to feel better in your home, powered by a sophisticated sensor analyzing volatile organic compounds (VOC).
Taking advantage of Apple's revolutionary HomeKit technology, Eve offers unparalleled ease of use, advanced security, and tight integration with Siri. Eve Room is powered by long-lasting, replaceable batteries, so you don't even have to deal with power cords.
About Eve
With Eve, see your home at a glance, right on your iPhone and iPad. The Eve family of HomeKit accessories gathers data on air quality, temperature, humidity, air pressure, energy consumption and more. Gain insights that help you improve your comfort, and make your home a smarter place. Use the free Eve app to view all data collected by Eve and control all accessories featuring HomeKit technology.
- Know your home: Eve Room senses indoor air quality, temperature, and humidity
- Improve your comfort: sophisticated sensor analyzing volatile organic compounds (VOC)
- Gain insights: your personal data by day, month or year
- HomeKit-enabled: unparalleled ease of use and advanced security
- Works with Siri: ask for temperature and humidity
- Truly wireless: powered by long-lasting, replaceable batteries
- Easy setup: direct connection using Bluetooth Smart technology, no hub or gateway required
*iPhone not included
Live smarter by knowing more about the place you care about most. With Eve Room, Eve senses indoor air quality, temperature, and humidity. -
Gain insights
See your home at a glance, and view beautiful graphs by day, month or year. Gain insights that help you improve your comfort, and make your home a smarter place. -
Air Quality beyond CO2
Eve Room is powered by a sophisticated sensor analyzing volatile organic compounds (VOCs). Air quality can vary based on many factors, and Eve Room goes beyond CO2 by analyzing substances that directly affect your well-being. -
Easy setup
Eve connects directly to your iPhone or iPad using Bluetooth Smart technology, without requiring a hub, gateway or bridge. -
Use your voice
Use Siri on your iPhone, iPad, or iPod touch to ask for temperature or humidity. -
Advanced security
HomeKit technology provides advanced security with end-to-end encryption and authentication between Eve and your iPhone, iPad, or iPod touch. -
Simply elegant
The Eve family has been carefully designed to seamlessly blend into your home environment. This elegance extends to truly wireless operation: thanks to Bluetooth Smart technology, Eve is powered by long-lasting, replaceable batteries, so you don't even have to deal with power cords.
- Eve Room - multipurpose sensor - Bluetooth 4.0
- Product Type
- Multipurpose sensor
- Environment
- Indoor
- Sensor Type
- Temperature, humidity, air quality
- Internet of Things (IoT) Platform
- Apple HomeKit
- Intelligent Assistant
- Siri - indirect
- Connectivity
- Wireless - Bluetooth 4.0
- Supported Host Device OS
- iOS
- 7.9 cm x 3.2 cm x 7.9 cm
- Product Type
- Sensor Type
- Environment
- Indoor
- Connectivity Technology
- iOS
- Internet of Things (IoT) Compatible
- Platform
- Apple HomeKit
- Communications Type
- Product-to-product
- Communications Technology
- Bluetooth Low Energy (LE)
- Siri
- Voice Controlled
- Indirect
- Included Accessories
- 3 AA batteries
- 7.9 cm
- 3.2 cm
- 7.9 cm
- 0 °C
- 55 °C
- 5 - 95%
