Live smarter by knowing more about the place you care about most. With Eve, see your home at a glance, right on your iPhone and iPad. The Eve family of HomeKit accessories gathers data on air quality, temperature, humidity, air pressure, energy consumption and more. Gain insights that help you improve your comfort, and make your home a smarter place.
With Eve Energy between your power outlet and electrical devices, Eve understands your energy consumption. Instantly see how much energy your devices are using, and switch them on or off with a simple tap or using Siri.
Improve your comfort
Live smarter by knowing more about the place you care about most. With Eve Energy, switch your devices on or off with a simple tap or using Siri, and instantly see how much energy your devices are using. -
Gain insights
See your energy consumption at a glance, and view beautiful graphs by day, month or year. Gain insights that help you improve your comfort, and make your home a smarter place. -
Easy setup
Eve connects directly to your iPhone or iPad using Bluetooth Smart technology, without requiring a hub, gateway or bridge. -
Use your voice
Use Siri on your iPhone, iPad, or iPod touch to control your devices connected to Eve Energy with just your voice. Assign custom names to your devices using the Eve app, and group them to access them simultaneously. -
Advanced security
HomeKit technology provides advanced security with end-to-end encryption and authentication between Eve and your iPhone, iPad, or iPod touch. -
Simply elegant
The Eve family has been carefully designed to seamlessly blend into your home environment. Bluetooth Smart technology makes setup a breeze, with no need for complicated WiFi setup and energy efficient, low power operation.
- Eve Energy - smart plug - Bluetooth 4.0
- Product Type
- Smart plug
- Environment
- Indoor
- Internet of Things (IoT) Platform
- Apple HomeKit
- Connectivity
- Wireless - Bluetooth 4.0
- Supported Host Device OS
- iOS
- 4.9 cm x 7.3 cm x 4.9 cm
- Product Type
- Smart plug
- Environment
- Indoor
- Connectivity Technology
- iOS
- Internet of Things (IoT) Compatible
- Platform
- Apple HomeKit
- Communications Type
- Product-to-product
- Communications Technology
- Bluetooth Low Energy (LE)
- Nominal Voltage
- AC 100/240 V
- 4.9 cm
- 7.3 cm
- 4.9 cm
