Eizo Generic Eizo LED Monitor 2560 x 1440 16:9 Black Bezel 2 x 1 built in
Quicklinx: 9W5SWS00 Mfr#: EV2736WFS-BK
The ergonomic and eco features of this 27" monitor make office work more comfortable while keeping power usage in check.
A thin bezel design saves space on the desktop and minimizes eye movement between screens in a multi-monitor environment.
  • Slim bezels
  • Getting connected
    Two input terminals are included for connecting to PCs. In addition, a USB hub and headphone/audio jacks are conveniently located on the side of the monitor.
  • Flicker-free images
    Due to the way brightness is controlled on LED backlights, a small number of people perceive flicker on their screen which causes eye fatigue. The FlexScan EV series utilizes a hybrid solution to regulate brightness and make flicker unperceivable without any drawbacks like compromising color stability.
  • IPS panel for a clear view from all angles
    The IPS (in-plane switching) panel has 178-degree viewing angles so it exhibits minimal change in contrast and hue when viewed from off center. This makes it ideal for trading rooms or other multi-monitor environments.
  • Tireless eyes
    To prevent eye fatigue, a brightness sensor called auto EcoView detects the changes in the ambient brightness that occur throughout the day and automatically adjusts the screen to the ideal brightness level. Auto EcoView cuts power by almost 40% compared to operating the monitor at maximum brightness.
  • Adjustable to just 0.2% of maximum brightness
    In a dimly-lit work environment, a monitor with low brightness settings will be more comfortable to use. This monitor comes with an LED backlight that allows for adjusting the brightness to just 0.2% of the maximum. With typical CCFL backlights the lowest you could adjust to would be a much brighter 20%.
  • Smooth playback of moving images
    An overdrive circuit reduces gray-to-gray response time to just 6 ms to ensure that moving images look clean and sharp.
  • LED backlights - less power, longer life
    Compared to conventional CCFL backlights, LED backlights last longer and consume less power. They are also mercury-free to have minimal impact on the environment when they are eventually disposed of.
  • Presence sensor for energy savings
    A presence sensor called EcoView Sense 2 prompts the monitor to switch to power save mode when you are absent and then power on again when you return. It even works in a multi-monitor setup so all monitors remain on when you're at your desk.
EIZO FlexScan EV2736W - LED monitor - 27"
LED-backlit LCD monitor - 27"
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms (grey-to-grey)
Colour Support
16.8 million colours
Input Connectors
DVI-D, DisplayPort
Speakers
Integrated
Display Position Adjustments
Voltage
64 cm x 24.55 cm x 39.95 cm
10 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
FCC Class B certified, TUV GS, C-Tick, DVI DMPM, TUV S, CB, ICES-003 Class B, CCC, TUV Ergo, DDC/CI, RoHS, ISO 9241-307, WEEE, GOST-R, cTUVus, EPA, VCCI Class B
5-year warranty
Display Type
Diagonal Size
27"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
59 - 61 Hz
Horizontal Refresh Rate
31 - 89 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Controls & Adjustments
Volume, brightness, contrast, H/V position, saturation, gamma correction, colour temperature, phase, smoothing, clock, hue
OSD Languages
Chinese (traditional), Chinese (simplified), English, German, French, Italian, Swedish, Spanish, Japanese
sRGB colour management, HDCP, BrightRegulator, Fine Contrast, Overdrive technology, Auto EcoView, EcoView Sense
64 cm x 24.55 cm x 39.95 cm - with stand
10 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 watt
DVI-D , DisplayPort , Audio line-in , Headphones , USB 2.0 upstream (Type B) , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
30
Swivel Angle
344
Rotation Angle
90
Height Adjustment
145 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x DisplayPort cable
Power Supply
Internal
Input Voltage
Power Consumption (Typical)
67 watt
Power Consumption Stand by / Sleep
0.5 watt
Included Software
ScreenManager Pro for LCD, EIZO ScreenSlicer
Dimensions & Weight Details
Without stand - width: 64 cm - depth: 6.5 cm - height: 37.9 cm - weight: 7.3 kg , With stand - width: 64 cm - depth: 24.55 cm - height: 39.95 cm - weight: 10 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 5 years
5 °C
35 °C
20 - 80% (non-condensing)
