Eizo EV2455-BK 24" 1920x1200 5ms VGA DVI HDMI IPS LED Monitor
Quicklinx: B0L7WS00 Mfr#: EV2455-BK
The monitor features a "fusion" design that combines EIZO's own EcoView technologies for reduced power consumption and improved visual ergonomics inside an extremely compact cabinet.
  • World's thinnest bezels for multi-monitor environments
    The monitor features 1 mm ultra-slim bezels on the sides and top with black borders of 4.3 mm and a depth of a mere 47.9 mm. This makes for an attractive design that blends in with the desktop and reduces eye movement in a multi-monitor setup.
  • Clear view from all angles
    The monitor uses an LED-backlit IPS (in-plane switching) LCD panel with 178° viewing angle that minimizes color shift and contrast changes when viewing the screen at an angle.
  • Auto brightness control
    To prevent eye fatigue, a brightness sensor called Auto EcoView detects the changes in the ambient brightness that occurs throughout the day and automatically adjusts the screen to the ideal brightness level.
  • Adjustable to less than 1% of maximum brightness
    In a dimly-lit work environment, a monitor with low brightness settings is more comfortable to use. With its LED backlight, thmonitor is adjustable to 1 cd/m2 which is less than 1% of the maximum.
  • 74% more flicker-free
    Due to the way brightness is controlled on LED backlights, many people perceive flicker on their screen which causes eye fatigue. The FlexScan EV series makes flicker unperceivable without any drawbacks like compromising color stability. In a comparison test conducted by EIZO, the monitor on average reduced flicker by more than 74% compared to LED-backlit monitors from other manufacturers.
  • Less blue light reduces eye fatigue
    In the visible light spectrum, blue light has wave lengths adjacent to ultraviolet light. Compared to the factory preset setting of 6,500 K of typical LCD monitors, Paper Mode is closer to the spectral distribution with long reddish wavelengths so it reduces the amount of blue light, a cause of eye fatigue, and helps prevent eyestrain when reading documents.
  • LED backlights - less power, longer life
    Compared to CCFL backlights, LED backlights last longer and consume less power. They are also mercury-free for minimal environmental impact.
  • Reduce power by up to 30%
    A feature called EcoView Optimizer 2 saves energy by up to 30% by reducing the backlight brightness and increasing the gain. To maintain image quality, EcoView Optimizer 2 only boosts the gain with a screen consisting mostly of dark content because the accompanying reduction in brightness is almost unperceivable.
  • Presence sensor for energy savings
    A presence sensor called EcoView Sense prompts the monitor to switch to power save mode when you are absent and then power on again when you return. It even works in a multi-monitor setup so all monitors remain on when you're at your desk.
EIZO FlexScan EV2455-BK - LED monitor - 24.1"
LED-backlit LCD monitor - 24.1"
Energy Class
Class A+
Energy Consumption per Year
22 kWh
Power Consumption (On mode)
15 W
USB 3.0 hub
Panel Type
IPS
Native Resolution
Full HD 1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.8 million colours
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Voltage
53.08 cm x 23.3 cm x 48.82 cm
6.5 kg
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, TUV S, CB, ICES-003 Class B, CCC, TUV Ergo, RoHS, WEEE, PSE Mark, GOST-R, cTUVus, J-MOSS, VCCI Class B, China RoHS, RCM
5-year warranty
Display Type
Energy Class
Class A+
22 kWh
Diagonal Size
24.1"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Native Resolution
Full HD 1920 x 1200
Pixel Pitch
0.27 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
55 - 76 Hz
Horizontal Refresh Rate
31 - 81 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
sRGB colour management, HDCP, BrightRegulator, Auto EcoView, EcoView Sense
53.08 cm x 23.3 cm x 48.82 cm - with stand
6.5 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
1 Watt
VGA , DVI-D (HDCP) , DisplayPort (HDCP) , HDMI (HDCP) , Headphones , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-5/+35
Swivel Angle
344
Rotation Angle
90
Height Adjustment
131 mm
VESA Mounting Interface
100 x 100 mm
1 x DVI cable - DVI-D to DVI-D , 1 x VGA cable
Power Supply
Internal
Input Voltage
15 W
Power Consumption (Typical)
49 Watt
On / Off Switch
Dimensions & Weight Details
With stand - width: 53.08 cm - depth: 23.3 cm - height: 48.82 cm - weight: 6.5 kg , Without stand - width: 53.08 cm - depth: 4.79 cm - height: 34.72 cm - weight: 4.1 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 5 years
5 °C
35 °C
20 - 80% (non-condensing)
