The monitor features a "fusion" design that combines EIZO's own EcoView technologies for reduced power consumption and improved visual ergonomics inside an extremely compact cabinet.
World's thinnest bezels for multi-monitor environments
The monitor features 1 mm ultra-slim bezels on the sides and top with black borders of 4.3 mm and a depth of a mere 47.9 mm. This makes for an attractive design that blends in with the desktop and reduces eye movement in a multi-monitor setup. -
Clear view from all angles
The monitor uses an LED-backlit IPS (in-plane switching) LCD panel with 178° viewing angle that minimizes color shift and contrast changes when viewing the screen at an angle. -
Auto brightness control
To prevent eye fatigue, a brightness sensor called Auto EcoView detects the changes in the ambient brightness that occurs throughout the day and automatically adjusts the screen to the ideal brightness level. -
Adjustable to less than 1% of maximum brightness
In a dimly-lit work environment, a monitor with low brightness settings is more comfortable to use. With its LED backlight, thmonitor is adjustable to 1 cd/m2 which is less than 1% of the maximum. -
74% more flicker-free
Due to the way brightness is controlled on LED backlights, many people perceive flicker on their screen which causes eye fatigue. The FlexScan EV series makes flicker unperceivable without any drawbacks like compromising color stability. In a comparison test conducted by EIZO, the monitor on average reduced flicker by more than 74% compared to LED-backlit monitors from other manufacturers. -
Less blue light reduces eye fatigue
In the visible light spectrum, blue light has wave lengths adjacent to ultraviolet light. Compared to the factory preset setting of 6,500 K of typical LCD monitors, Paper Mode is closer to the spectral distribution with long reddish wavelengths so it reduces the amount of blue light, a cause of eye fatigue, and helps prevent eyestrain when reading documents. -
LED backlights - less power, longer life
Compared to CCFL backlights, LED backlights last longer and consume less power. They are also mercury-free for minimal environmental impact. -
Reduce power by up to 30%
A feature called EcoView Optimizer 2 saves energy by up to 30% by reducing the backlight brightness and increasing the gain. To maintain image quality, EcoView Optimizer 2 only boosts the gain with a screen consisting mostly of dark content because the accompanying reduction in brightness is almost unperceivable. -
Presence sensor for energy savings
A presence sensor called EcoView Sense prompts the monitor to switch to power save mode when you are absent and then power on again when you return. It even works in a multi-monitor setup so all monitors remain on when you're at your desk.
- EIZO FlexScan EV2455-BK - LED monitor - 24.1"
- LED-backlit LCD monitor - 24.1"
- Energy Class
- Class A+
- Energy Consumption per Year
- 22 kWh
- Power Consumption (On mode)
- 15 W
- USB 3.0 hub
- Panel Type
- IPS
- Native Resolution
- Full HD 1920 x 1200
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.8 million colours
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 53.08 cm x 23.3 cm x 48.82 cm
- 6.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, TUV GS, TUV S, CB, ICES-003 Class B, CCC, TUV Ergo, RoHS, WEEE, PSE Mark, GOST-R, cTUVus, J-MOSS, VCCI Class B, China RoHS, RCM
- 5-year warranty
- Display Type
- Energy Class
- Class A+
- 22 kWh
- Diagonal Size
- 24.1"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Vertical Refresh Rate
- 55 - 76 Hz
- Horizontal Refresh Rate
- 31 - 81 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- sRGB colour management, HDCP, BrightRegulator, Auto EcoView, EcoView Sense
- Black
- 53.08 cm x 23.3 cm x 48.82 cm - with stand
- 6.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 1 Watt
- VGA , DVI-D (HDCP) , DisplayPort (HDCP) , HDMI (HDCP) , Headphones , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 344
- Rotation Angle
- 90
- Height Adjustment
- 131 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DVI cable - DVI-D to DVI-D , 1 x VGA cable
- Power Supply
- Internal
- Input Voltage
- 15 W
- Power Consumption (Typical)
- 49 Watt
- On / Off Switch
- Dimensions & Weight Details
- With stand - width: 53.08 cm - depth: 23.3 cm - height: 48.82 cm - weight: 6.5 kg , Without stand - width: 53.08 cm - depth: 4.79 cm - height: 34.72 cm - weight: 4.1 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 5 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
