EE and BT Home Phone Adapter
Quicklinx: J1RLWS00 Mfr#: 001366-3
More than 50 In Stock
£16.66 ex VAT
£19.99 inc VAT
Express delivery Order within the next 22 hours for delivery on Monday
This Adapter allows you the freedom to keep using your existing home phones when your service moves to Digital Voice or Digital Home Phone. If your current home phone is a DECT Cordless phone, with or without additional handsets, you will only need 1 Adapter. Suitable for residential lines only. If you only use Corded phones in your home, you will need an Adapter per phone. (You can have up to 5 Digital Voice products registered to the Smart Hub, this includes the Digital Voice Adapter)
You require an adapter if:
  • You want your DECT phone in a different location to your Smart Hub. You'll only need 1 Adapter
  • You use Corded phones around your house. You'll need an Adapter per Corded phone
You do not need an adapter if:
  • It's convenient for you to plug either your Corded or Cordless phone directly into the green port at the back of your Smart Hub.
Please note - not for use with healthcare alarms or medical pendants
Brand: EE
