Stream your favourite shows from the backseat!
New 4GEE WiFi designed for the car gives internet access to everyone you're travelling with, letting the driver keep their eyes on the road.
It allows passengers to check their newsfeeds, stream music, play online games and watch films or TV programmes - making car journeys much more fun for everyone. Car WiFi on the EE network. It's a game changer.
Plenty for everyone
Car WiFi makes car journeys more fun and entertaining for everyone you're travelling with. Designed specifically to be used in the car, it plugs into your 12 volt power socket which means it'll never run out of power and you don't need to remember to recharge it. Car WiFi from EE supports up to 10 WiFi enabled devices at once (like tablets and laptops), so everyone in the car can go online at the same time.
What's in the box?
- Device
- Keep Me Card
- Keep Me Card Stickers
- Quick Start Guide
- Safety Info Leaflet
- EE Sim card - 2GB of data every month for 3 months
DIMENSIONS
Size: 59mm × 49mm × 88mm
Weight: 50g
Compact and portable
The 4GEE WiFi Mini is significantly smaller and fits into a pocket, allowing customers to easily carry their own secure Wi-Fi connection with them. -
Keep going for longer
The power of the 4GEE WiFi Mini is matched by the performance of its hard-working battery, offering long hours, with an impressive long hours stand-by time. With the 4G coverage, you can rely on both the battery and their network to keep you online for longer, wherever you are.
