Get an instant connection on the go
Easily connect your tablet or any other device when you’re out and about to EE’s 4G network. With our 4GEE mobiler broadband you can connect up to 20 devices at once, such as tablets, computers and game consoles, so all your family or friends can get online, at the same time
Delivered through 4GEE on the UK’s fastest network, you can get average speeds of 31Mb/s in some places, that’s faster than standard fibre broadband.
Superfast speeds
- If you live in a slow speed area, our 4GEE WiFi Mini can give you faster speeds over the 4G network.
- No need for a landline: There’s no wait to get a landline installed, so you can start using your 4GEE WiFi Mini instantly.
- Set-up in seconds: There’s no engineer visit or wait to get installed. Just plug in the power to get connected instantly.
- 30m WiFi range: With its increased range, your WiFi signal is distributed effectively all through your home.
- Connect up to 64 devices: With the ability to connect up to 64 devices, you can keep the whole home connected on multiple devices.
Spec
- Memory: CPU Cortex-A7 CPU Core 1 Internal memory 256.0 GB
- Size & Width: Depth 13.3 mm Height 62.5 mm Weight 85.0 g Width 92.0 mm
- Connectivity: Wi-Fi 802.11a/b/g/n/ac
- Battery: Capacity 2150.0 mAh Lasts up to 12 days
Requires EE Data Plan
EE 4GEE WiFi Mini 2020
